Magnavox oso vcr directions
When i try playing a video it looks fuzzy is there a tracking button on the remote or player
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
baghdad_love
  • 56 Answers
SOURCE: adding a combo DVD/VCR player to my remote
you can find all the codes in this web site .. http://www.remote-codes.com/ please rate me if this work !
Posted on Jul 31, 2007
SOURCE: no sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Posted on Jan 16, 2008
SOURCE: Philips Magnanox Universal Remote CL034
I found this website and it has the codes for everything for your universal remote. Good Luck.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Feb 14, 2008
SOURCE: I need the codes for a Magnavox dvd vcr player and a Orion tv.
I have a one for all remote, i have no codes for a coby dvd player.Can some one help with the codes?
Thank you, Don
Posted on May 01, 2008
Lost manual for DVD Recorder/VCR ZV450MW8 Need instructions to copy DVD Disk to VDD Disk or e-mail manual
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
The Magnavox ZV450MW8 was manufactured by Funai with the Magnavox name. Thus Funai Service has the manual available: http://www.funaiservice.com/manual2012_search2.php . The direct link is http://www.funaiservice.com/manuals/MAGNAVOX/ZV450MW8/ZV450MW8.pdf . The directions for dubbing a DVD to VCR or vice versa start on page 48. Note: copy protected items cannot be duplicated.
I hope this helps.
Dec 10, 2014 | Televison & Video
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
We have a Magnavox VCR/DVD player. When pressing the VCR/DVD button it will not switch from VCR to DVD.
I have found this to be a problem with my Magnavox MWD2205. It seems to be a problem that Magnavox (actually FUNAI CORP.) can't seem to understand and fix on their machines.
1. Pick up your remote and press the video button.
2. Press the DVD button.
3. Press the Video button.
4. Press the DVD button.
That simple. This usually works but no guarantee.
Also check on the back of you player and see what cable you have connected. Often times S-Video will be plugged in and so VCR won't function. Or VCR composite video (the little yellow round port) will be plugged in and so your digital DVD won't function either. Make sure that whatever media format you choose that your ports correspond with the chosen format.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Magnavox MWR20V6 DVD
I purchased a Magnavox MWD7006 and need to have it play in Db5.1 KOSS Entertainment system; thus far only plays in stereo; anyone know what I'm missing? I'm using a S-Video cable.
Dec 15, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
