Code:HDCP-019 - Televison & Video
How can I fix the error code 019 E on my Eloctrolux washing mashine W355H
You probably need a new board, but why not call the local parts supplier and tell the guy you're getting an 019 and he should be able to get you started. Just every now and then you may get around, but more than likely your will need to replace the board.
Mar 24, 2015 | Electrolux Washing Machines
Insignia tv issues
Your Insignia TV probably has had an internal power supply failure
Oct 13, 2013 | Insignia Televison & Video
Hdmi wont work did the SELF DIAGNOSTIC FUNCTION and it says hdmi no 40705122 err code 81
the hdmi is a hdcp circuitry meanining it handles high-bandwith digital content protection hence the hdcp its a security copy device that protects a device from intercepting digital data, this error code means its corrupted and needs to be reprogrammed digitally u will need an computer tech conversant with computer digital electronics
Jul 14, 2013 | Toshiba 57H82 57" Rear Projection...
$400{(1-(1+.019/12)^-60 / .019/12 I am trying to enter this equation on my TI 30XS calculator and keep getting a syntex error
The problem should be 400((1-(1+.019/12)^-60)/(.019/12))
You can enter it almost exactly as given:
4 0 0 * ( ( 1 - ( 1 + . 0 1 9 / 1 2 ) ^ 6 0 (-) ) / ( . 0 1 9 / 1 2 ) ) ENTER
Make sure you use (-) instead of - to enter the negative number.
Feb 28, 2012 | Office Equipment & Supplies
I cant program my remote. Its a " one for all" remote and my tv is PhillpsMagnaxox. Please tell me a code.
Philips TV Codes-003-004-008-012-019-062-068-069-075-076-086-087-088
Magnavox TV Codse 004-006-008-019-062-068-069-075-076-077-088-130-131-132-133-134-183-196-219-235
Aug 03, 2011 | Philips Televison & Video
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
I cannot view HD channels (from freeview HD box) through my Sony str-dh810. I've narrowed the problem down to something called HDCP. When HDCP is on, I cannot view anything from my freeview box. Turning...
This piece of information should solve your problem:
High-bandwidth Digital Content Protection (HDCP) is a form of Digital Rights Management (DRM).
There is a licensing body that issues licenses for HDCP devices. Each HDCP-compliant device, like your Blu-ray player or Xbox, has a license and the ability to talk to the receiving device on the other end of the HDMI cable. The outputting device says "Hey display! Are you HDCP compliant? Here is my license, show me your license!" The display (or other HDCP compliant device) returns with "Why yes, I am legit! Here is my license!" When that process works, it happens within a thousandth of a second and you, the consumer, never even notice. You power on your Blu-ray player or DVR, it makes nice with your HDTV, and you live a happy life never knowing what HDCP even is.
if you have an older HDTV set that is not HDCP compliant then you cannot watch any HDCP compliant content on it. If you plug in your HDCP-compliant device to a non-compliant device, you'll either see a blank screen or an error message like "ERROR: NON-HDCP OUTPUT," "HDCP unauthorised," or simply "HDCP ERROR."
Short of buying a new television or giving up on your video game project the only way to deal with your HDCP compliance problem is to buy a cheap HDMI splitter that ignores HDCP requests.
Sep 25, 2017 | Sony STRDH810
Need to get code for 3-1 remote # 1519001
TV Brand 3-in-1 Code Radio Shack Cat. No.
Akai 098
Anam 068, 180
Anam National 055, 161
AOC 019, 030, 052, 137
Candle 030, 046, 056, 186
Capehart 052
Citizen 030, 039, 046, 056, 060, 092,
186
Concerto 056
Contec 158, 180, 185
Craig 161, 180
Crown 039
Curtis Mathes 030, 039, 060
CXC 180
Daewoo 019, 039, 091, 092
Daytron 039
Electrohome 039
Emerson 039, 158, 177, 178, 179, 180,
181, 182, 183, 185, 236, 270,
280, 282
Envision 030
Fisher 154, 159
Fortress 093
Fujitsu 179
Funai 179, 180
Futuretech 180
GE 021, 027, 029, 047, 051, 055,
174, 178, 282
Goldstar 001,019, 039,056, 106, 178
Hallmark 178
Hitachi 038, 039, 056, 095, 097, 145,
151, 173, 227
Infinity 054
JBL 054
JVC 053, 169
Kenwood 030
Kloss 046
Kloss Novabeam 024
KMC 106
KTV 039, 180, 280
Logik 016
Luxman 056
LXI 047, 054, 148,154, 156
Magnavox 020, 024, 028, 030, 054,
096, 186, 187
Marantz 030, 054
Memorex 016
154 16-229
178 16-254
16-263
16-280
MGA 019, 030, 150, 155, 178
Mitsubishi 019, 098, 155, 178
Mitsubishi Unified 150
MTC 019, 030, 056, 060, 091
Multitech 217
NAD 156, 166
NEC 019, 056, 170
NEC Unified 030
Onwa 180
Optonica 093, 165
Panasonic 051, 054, 055, 162
Penney 018, 019, 021, 030, 039, 047,
060, 135, 149, 019, 020, 024,
028, 030, 054, 186, 187
Phillips 000, 054
Pioneer 038, 166
i think this will help you a lot.
Aug 03, 2009 | Televison & Video
Code for universal remote
Abex 172
Admiral 001, 173
Advertura 174
Aiko 016
Akai 002
Alleron 046
Amtron 038
Anam National 003, 038
AOC 006, 005, 004, 007
Audiovox 038
Belcor 004
Bell & Howell 001, 083, 162
Bradford 038
Brokwood 004
Candle 004, 006, 008, 174
Celebrity 002
Citizen 016, 171, 004, 006, 008
038, 105, 174, 177
Colortyme 004, 006
Concerto 004, 006
Contec / Cony 012, 013, 038
Craig 038 v
Crown 038, 171 v
Curtis Mathes 171, 000, 004
006, 015, 105, 162
CXC 038
Daewoo 016, 190, 005
171, 004, 006, 017, 127
Daytron 004, 006, 171
Dimensia 000
Dumont 004, 151
Dynatech 004
Electroband 002
Electrohome 004, 006
002, 003, 019, 022
Emerson 030, 171, 191, 004
038, 046, 006, 012, 023, 024, 025
026, 027, 028, 029 031, 032,
033, 034, 035, 036, 037, 039
041, 042, 043, 044, 047, 123
124, 162, 177, 179
Envision 004, 006
Fisher 048, 049, 051, 162, 180
Fujitsu 046
Funai 038, 046
Futuretec 038
GE 000, 054, 003, 004, 006
022, 052, 055, 087, 164, 165
166, 167, 168, 181
Gibralter 004, 151
Grundy 171, 038, 046
Hallmark 004, 006
Harvard 038
Hitachi 059, 004, 148, 006, 012
013, 060, 061, 135, 136, 137
138, 139, 140, 141, 142, 143
144, 145, 146, 150, 179
IMA 038
Infinity 062
Janeil 174
JBL 062
JCB 002
JC Penny 000, 054, 005, 171
004, 052, 006, 172, 008, 022, 058
063, 064, 072, 087, 105, 181
Jensen 004, 006
JVC 159, 013, 012, 182, 054
060, 065, 066, 067, 123, 157, 158
Kawasho 002, 004, 006
Kenwood 004, 006, 019
Kloss Novabeam 068, 069, 174, 183
KTV 171, 038, 177, 070
LG (Goldstar) 005, 156, 004, 006
172, 012, 019, 056, 057, 058, 155, 171
Loewe 062
Logik 083
Luxman 004, 006
LXI 000, 062, 006, 073
162, 181, 049, 072
Magnavox 062, 004, 006, 130
134, 183, 008, 019, 068, 069
075, 076, 077, 088, 131
132, 133, 219, 235
Majestic 083
Marantz 004, 006, 062
Megatron 006, 059
Memorex 083, 006, 001, 082, 162
MGA 005, 004, 006
079, 082, 019, 022, 051, 080
Midland 054, 151, 171, 172, 181
Minutz 052
Mitsubishi 005, 004, 006
125, 082, 081, 019, 022
051, 079, 080, 135
Montgomery Ward 083
Motorola 003, 173
MTC 005, 004, 105, 006
Multitech 038
NAD 006, 185, 072
NEC 005, 004, 006, 003
Nikko 006, 016
NTC 016
Onwa 038
Optimus 185
Optonica 095, 173
Orion 191, 035
Panasonic 170, 054, 062, 003
Philco 062, 005, 004, 006, 183
008, 012, 019, 003
068, 069, 075, 077
Philips 062, 004, 075, 008, 019
003, 012, 068, 069
076, 086, 087, 088
Pilot 004, 171
Pioneer 004, 006, 090
091, 092, 136, 179, 185
Portland 016, 005, 171, 004, 006
Price Club 105
Prism 054
Proscan 000, 181
Proton 004, 006, 012, 093
Pulsar 151
Pulser 004
Quasar 003, 054, 070
Radio Shack / Realistic 000, 095, 171,
004, 038, 006, 012, 049, 162
RCA 000, 181, 100, 233, 203
212, 098, 005, 003, 004, 006
007, 019, 096, 099, 101, 102, 103
129, 179, 188, 190
Runco 151
Sampo 004, 006, 171, 172
Samsung 171, 004, 005, 105, 006
012, 015, 017, 019, 104, 106, 172
Sansui 191
Sanyo 048, 080, 004
180, 162, 169, 049
Scotch 006
Scott 004, 038, 046
006, 012, 024, 035
Sears 000, 048, 189, 004, 046
006, 013, 019, 049, 051, 066
072, 162, 180, 181
Sharp 173, 095, 171, 004, 006
012, 029, 111, 112, 113, 122
Shogun 004
Signature 001, 083
Simpson 008
Sony 002, 218
Soundesign 004, 038, 046, 006, 008
Squareview 189
SSS 004, 038
Starlite 038
Supre-Macy 174
Supreme 002
Sylvania 062, 004, 006, 088, 076
116, 008, 019, 068, 069
075, 077, 161, 183
Symphonic 038, 189, 033
Tandy 173
Tatung 003
Technics 054
Techwood 004, 006, 054
Teknika 016, 005, 171, 004, 006
008, 012, 013, 038, 046, 076
082, 083, 105, 170
Tera 004, 012, 093
TMK 004, 006
Toshiba 105, 162, 160
161, 049, 072, 118
Totevision 171
Universal 052, 087
Victor 066, 182
Vidtech 004, 005, 006
Viking 174
Wards 000, 062, 095, 005, 004
046, 052, 006, 083, 001, 019
024, 033, 068, 069, 075, 076
087, 088, 119, 120
Yamaha 004, 005, 006, 019
Zenith 051, 083, 004, 152
151, 153, 154, 217
Nov 08, 2007 | Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
