Question about Nokia 6288 Cellular Phone
Please help me
My phone became blank after the nokia logo appear.
  • 490 Answers
Try to turn on ur handset without mamory card if its gets turn on then u have installed that application on ur memory card which is creating a problem or contact nokia care
Posted on Oct 14, 2007
SOURCE:
My nokia 6500s-1 when i switch on then after the logo of of nokia showed on the screen the date settings appeared and after a few seconds it goes blank then it automatic turns off? please help...
It is definitely software.problem .To solve this we need to flash/update the phone .If you do not want to concern a mobile tech.Follow the tricks
My fixya Tips Good luck.Thanks for visiting Fixya
Jul 26, 2011 | Nokia 6500 Slide Cellular Phone
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
Hii My Nokia 5130 Express Music phone doesnt start up. It shows "test mode" on plugging the charger. Even otherwise, on starting the phone the Nokia logo appears ten the screen goes white and switches...
please format your phone using first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
Oct 20, 2010 | Cell Phones
Cannot display oplogo
First download the operator logo from google. Then use this program that I have found really helpful is Oxygen Phone manager. You can download it http://www.oxygensoftware.com. Using the trial version, you can still change your operator logo. First, use PC Suite to transfer the downloaded file, from this thread, from your computer to your phone. I placed the file in my image file on my phone's memory. Then completely log out of PC Suite. Connect your phone to your computer by infrared or dku cable and open oxygen. Once your phone is found by oxygen, you click on the gallery section underneath the icon of your phone and select the file location where you stored the file. On the right information box of Oxygen, there is a picture of a phone in the selection panel. Click the picture that allows your to upload the information from your phone to the computer. When you see the file, blank logo, appear, right click it and choose "select as operator logo". Rate me!!
Aug 23, 2009 | Nokia 3230 Cellular Phone
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
May 30, 2009 | Nokia 3230 Cellular Phone
Hi Friend,
Initially u have remove the sim card and the battery.
Once u have removed insert only the battery and put to charge for 10 to 15 mins.
then remove the mobile from charger and insert the sim card.
Now after 30 sec switch it on.U will be able to do the process
Regards,
Ayyasam
May 29, 2009 | Nokia 3230 Cellular Phone
Nokia 6020 won't start up
Unfortunatly check info service usually means your phone is moisture damaged.Especially if the screen goes blank.Check if the charger unit has turned slightly green and mouldy looking.Take off the back cover and check the battery does not look warped and also remove the front fascia and check for signs of staining on the keypad.It is not a screen problem if the logos are still appearing .it is an internal problem.If your phone is moisture damaged there is no way of repairing it.Bring it to a mobile repair shop to get it opened up and examined.hope this helps
Sep 26, 2008 | Nokia Handsfree For 6020, 6101, 6102...
Nokia 6288 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
