When our dryer is on it seems that things like draw string, zippers and shirt corners get stuck...
(More)
When our dryer is on it seems that things like draw string, zippers and shirt corners get stuck between the rotating drum and the stationary part of the machine. It either eats them or discolors the fabric so bad it can't be worn. Is their any way to fix this issue?
ge dryer model dvl223eaww wiring diagram needed. the control panel separated from the dryer - need...
(More)
GE DRYER MODEL DVL223EAWW WIRING DIAGRAM NEEDED. THE CONTROL PANEL SEPARATED FROM THE DRYER - NEED SCHEMATIC TO RECONNECT COLO CODED WIRES
the light is on inside of the dryer but after i put the clothes in and turn the start knob. nothing...
(More)
the light is on inside of the dryer but after i put the clothes in and turn the start knob. nothing happens... what could the problem be?
I have model DVL223EAOWW - 120/240 vol - Ge Extra large cap.. I took the dryer completely apart,...
(More)
I have model DVL223EAOWW - 120/240 vol - Ge Extra large cap.. I took the dryer completely apart, cleaned all hose's vents doors heating elements etc.. ( I took a ton of lint out ) I took the drum out & checked the heating element etc.. The element goes on and shuts off as it should. Yet once i run a cycle it still takes almost 2+ cycles to dry.. Also I notice on the top right hand corner ( Flat top ) the surface becomes hot has hell. - The back vent is not blocked and is clear. What could the problem be?
