Question about John Deere 22HP Hydrostatic 42" Riding Mower
John Deere x500 3 blade mower deck leaves strip of grass
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
  • 11 Answers
SOURCE: 320 john deere mower starts sputtering and pulling
How old is the battery, and is it in good condition?
Posted on May 05, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
wentlanv
  • 710 Answers
SOURCE: I was mowing in tall
Sounds like you're having a problem with your Power TakeOff system. The first thing to do is check to see if you didn't bump the PTO switch on your dash. Since you were in tall grass, check to see that there is nothing obstructing your machine.
If all appears OK, then the PTO should be tested. This is an electrical problem and requires a multimeter.
Before you test, check your battery to see if it's charged and that the terminals are clean.
For information on testing the PTO system, I'm pasting a web address with detailed instructions: >>>> http://www.ehow.com/how_7725472_troubleshoot-pto-system-john-deere.html
Copy and paste this link into your browser's address bar.
Good luck to you.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 16, 2011
  • 93 Answers
SOURCE: When mowing with my John
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Posted on Aug 19, 2011
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
Mower leaves strip of grass unmowed in center of deck. This is a model X300 with newly sharpened blades
Check the center blade to make sure it spins freely when the deck belt has been removed. The spindle may have frozen up.
May 26, 2016 | John Deere Garden
Why does my riding tractor leave a strip of grass that isnt cut
It is probably an indication of worn mower blades. Installing new ones should solve the problem. Hope this helps.
Bob
Jul 31, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
1993 john deere 445 surging and popping down on power won't spin mower deck fast enough to cut grass. seems to be running rich.
sounds like the flote is stuck down in the carb thats causing it to flood up strip card and give it a goofd clean out
its that or the mower deck is sezed up or the blades are rounded off and your stalling the engine trying to turn it and cut grass,, have a look at them as well,,,
Nov 17, 2009 | Garden
John Deere 22HP Hydrostatic 42" Riding Mower Logo
46 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
