Question about Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD goes into lockout. We can get it out of lockout but goes back into lockout at any movement of the chair........
    Scholar:
  • 90 Answers
Make sure any seating system is completely down and in DRIVE position. When chair is unlocked, wait 5 seconds, shut chair off, wait 5 seconds, turn chair back on. Each time you turn the chair on you need to wait 5 seconds for the POST to complete before moving the joystick.
Posted on Oct 29, 2013
Why won't the jazzy chair turn back on. I only get running lights on the controller
Is the controller locked? Does the controller beep? The best way to troubleshoot the problem is to go up on Jazzy's website and download the service manual
Oct 07, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
How move ypushing--battery dead
On the back of the chair, there is a lever that dis-engages the drive motor to allow you to push the chair.
Aug 15, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
www.gewizrepairs.co.uk
Jul 05, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
The right side is disengaging. It goes around in circles to the right.
Go to Pride Mobility Products Corp Basic Troubleshooting Instructions This page can assist you. There is also a lever to disengage the wheels that allow the chair to be rolled when not powered. Look at your manual to find the location.
Nov 02, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I have an error code of three on my jazzy 614hd power chair
hi, Please take a look at the following link:
http://www.pridemobility.com/resourcecenter/Downloads/Basic_Troubleshooting_Guides/basic_troubleshooting_guides.asp
Regards
Feb 17, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
I just bought a used jazzy 614hd if the ground is just a slight bit unlevel it just sits and spins what can i do to fix this? also the joy stick is so sensitive i can't go straight can it be adjus
Augh!
This is another Pride Jazzy / Quantum motor issue. The wires that feed the motor break inside the insulation at the point of entry into the motor.
As a used chair there is no warranty to you, nor are there any recall protections.
Your motor(s) need(s) to be replaced or rebuilt.
Nov 04, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Chair beeps when off
The PGDT controller may have been programmed to go into sleep mode. If so, if the chair isn't used for up to 10 minutes, the chair will go into sleep mode - then beep every once in a while to remind you it is sleeping.
Go ahead and wake it up and then shut it off. It won't mind.
Oct 05, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Pride Jazzy 614 Hd JAZZY 614HD Logo
159 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
