Question about NRS Tool Aid Comprehensive Fuel Injection Pressure Test Kit
Air Conditioner 1992 Mitsubishi Diamante 3.0L, SOHC When I turn on the AC, it blows out cold air sometimes. And at times it blows out hot air. Doesn't work properly.
  • 55 Answers
Have it serviced by a shop probalby needs it recharged
Posted on Apr 24, 2009
  • Kevin Penney
    Kevin Penney Jun 22, 2012
    If it is blowing cold sometimes and sometime not, a charge probably isn't what it needs. Sounds like either an a/c clutch issue or more likely, a malfunctioning blend valve. The blend valve is a mechanical louver that is either electrically or vacuum operated, and it channels hot air in to mix with cold air.
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Air conditioner blows super hot air.
your ac is freezing up try replacing the expansion valve
Aug 17, 2009 | 1992 Oldsmobile Cutlass
Air conditioner blows hot air . gauge shows full .
It needs to be re-gassed. Take the car to an Auto Mechanic to get the Air-Conditioning re-gassed. They might also need to check it for leaks to make sure the gas stays in.
Jul 26, 2009 | 1994 Mitsubishi Diamante
Air conditioner blows out hot air
Hi, my name is Ron,Is the freon level right or to much or to little amount of freon?Does the ac accumilator get really cold?The pipe coming off the accumelator ?If so,look for a vacuum line to be colasped or leaking,and check vacuum resorvoir to see that it is not leaking vacuum...any more help...roniecon@gmail.com
Jul 19, 2009 | 1994 Oldsmobile Cutlass Ciera
Alternator removel on a 95 mitsubishi diamante
3.0 SOHC. TURN OFF RADIO. THEN DISCONNECT BATTERY NEGATIVE CABLE.REMOVE AIR CLEANER ASSEMBLY.LOOSEN THE TENSIONER PULLEY.REMOVE ALTERNATOR DRIVE BELT .REMOVE ACCELERATOR CABLE.REMOVE.BRAKE BOOSTER VACUUM HOSE.REMOVE EGR VALVE.REMOVE ALTERNATOR ELECTRICAL CONNECTORS. THEN REMOVE MOUNTING BOLTS THEN REMOVE ALTERNATOR. THE 3.0 DOHC DISCONNECT NEGATIVE BATTERY CABLE.REMOVE SURGE TANK.REMOVE AIR DELIVERY HOSES TO GAIN ACCESS TO THE ALTERNATOR .IF YOU HAVE AIR CONDITIONER .REMOVE THE CLAMP .RAISE THE SUCTION HOSE.USE SOMETHING TO HOLD IT OUT OF THE WAY.LOOSEN TENSIONER PULLEY .AND REMOVE THE ALTERNATOR DRIVE BELT .DISCONNECT THE OXYGEN SENSOR CONNECTOR .DISCONNECT THE ALTERNATOR ELECTRICAL CONNECTORS.REMOVE ALTERNATOR BRACKETS AND MOUNTING BOLTS .REMOVE THE BRACKET AND ALTERNATOR AS A ASSEMBLY.SEPARATE THEM ON A WORK TABLE.
Jul 05, 2009 | 1992 Mitsubishi Diamante
Air blowing out of Air Conditioner but it is not cold!
when you regassed did you check for leaks and could you see flow through the sight glass. if the answer is yes to both i would say the compressor has had it.
Jun 20, 2009 | 2001 Mitsubishi Diamante
A/C promblem
try driving around for almost 4 months and the damn thing wont blow cold. try spending thousands of dollars and it still being broken. and trying driving in florida in upwards 115 degrees with no cold ac everyday. you only have to wait 30 minutes? count yourself lucky!
Jun 19, 2009 | 2001 Mitsubishi Galant
AC not blowing cold air at times
poss causes are, sticking low pressure switch, defective Ac compressor clutch closing coil or incorrect clutch driven plate air gap, spec is 0.26 thousands.
May 11, 2009 | 2003 Ford ZX2
Air conditioner blows hot cold and sometimes not at all why?
hello,seem you need to send your car to authorized dealer to scan the problem,maybe the solution is only synchronizing all the flap,ty
Apr 24, 2009 | 2000 Mercedes-Benz CLK
NRS Tool Aid  Comprehensive Fuel Injection Pressure Test Kit Logo
91 people viewed this question
Top NRS Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a NRS Measuring Tool and Sensor Expert? Answer questions, earn points and help others
