The 110 fields are causing problems
The problem we are having is this. we are on a job that requires consolodation points. we are using cat6 systemax cable and jacks and patch panel. they wanted consolodation points which are the 110 fields where they cross connect then go to the drop. We are barely able to pass any of the drops. we have to pinch the pairs togther at the connections in the 110 blocks and we will re-do the jacks over and over until they pass and they will only pass by like 0 db's or a little better it has us guys a little confused and anyone we have talked to has not seen or done anything like this. and the deadline for the job is coming up
  • 164 Answers
R u talking about 110 phone blocks? That doesnt belong in this forum
Posted on Jul 24, 2009
Connect talktalk new router
You should be just fine with the cabling that you have. I am betting you have Cat5 or Cat5e. The upgrade would be Cat6. I doubt your new router would be sensitive enough to require a specific grade data cable. Your speed has to be slow from low RAM, too many start up apps running or from the service provider.
Aug 14, 2014 | Computers & Internet
Tip
My required cable ( cat5 or cat6 )
if you need to transfer data at less then 300 MB/S then use cat5 cable and insert the switch at minimum after 300ft. length.
if data rate is in gaga Bytes then use the cat6 other wise don't waste money on cat6.
on Jun 30, 2011 | Computers & Internet
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
1mtr cat6 patch cable how mutch it cost please ? i need 1000 pc
It should cost around US$ 4.00 per cat6 patch cable. For 1000 pc. you must negotiate with the amount to get a better price quote.
Apr 05, 2011 | Systemax CAT6 Patch Cable
I have a petrol generator, it puts out 110 and 230 the switch that changes over is a on/on switch when it was running my mate switched it over to 110 from 230 and the was a flash now it does not put out...
You probably will need to replace the switch if it flashed over. I would disconnect it and document the exact connections before as there are usually a bunch of wires to the switch. Test the switch with an ohmmeter.
The flashover MAY have discharged the magnetic field of the rotor and you may have to "flash the field" to restore it. Google "flashing field" as there are a lot of methods.
Worst case is if the unit is a brushless generator and the flash over in the switch shorted the rotating diodes on the rotor. That will require servicing of the generator part of the unit to replace the diode modules.
May 03, 2010 | Coleman Powermate Powermate 5000W...
What is the difference between, cable cat6 systemax, China and the U.S
shouldn't be any, cat6 is an industry standard therefor the same across the board. If you are referring to the cable itself there could be stuff such as coloring on the cables, but functionality NONE.
Apr 15, 2009 | Systemax CAT6 Patch Cable
How to setup secured printting on a xerox workcenter pro90 copier?
Solution: Send a Secure Print Job From a Workstation bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. With your document open in the application, click on [File] on the toolbar and then select [Print] from the menu. The Print window will be displayed.
  2. Select the printer in the Name field.
  3. Click on the [Properties] button.
  4. Click on the [Paper / Output] tab.
  5. Select [Secure Print] from the Job Type pull-down menu.
  6. Click on the [Setup] button (just below the Job Type menu) and enter a 4 to 10-digit code, to release the job at the printer, in the Enter a 4-10 Digit Secure Print Passcode field.
  7. Enter the code again in the Confirm 4-10 Digit Secure Print Passcode field, and then click [OK].
  8. Make any other required selections in the print driver and the click [OK] twice to send the job to the printer.
Solution: Enable Release All for Secure Print bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution as it requires knowledge of the network’s Authentication environment.
The WorkCentre Pro will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address).Before you begin, print a Configuration Report and make sure the WorkCentre Pro has an IP address, and the HTTP protocol enabled. See the Related Items below.
From the workstation:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to open an Internet Explorer browser window.
  2. Enter the IP Address for the WorkCentre Pro followed by /diagnostics/secureReleaseAll.dhtml in the Address field, and then press [Enter] on the keyboard. For example, type: xx.xxx.xxx.xx/diagnostics/secureReleaseAll.dhtml (where x represents the IP Address). A Secure Print Release All window will be displayed.
    NOTE: The URL is case sensitive; secureReleaseAll must contain a capital R and capital A.
  3. When prompted, enter the username and password in the fields provided.
    NOTE: The default username is admin and is case senstive. The default password is 1111.
  4. Click on the check box next to [Enable release of all secure print jobs with the same user name and passcode] to insert a check mark.
  5. Click on [Apply].
  6. Click on the [X] in the upper, right corner to close the browser window.
Oct 03, 2008 | Xerox Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
