Question about Maytag MTB1504ARS Top Freezer Refrigerator
Maytag mtb1504ar how to install ice maker
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MSD24GR ICE MAKER
you need to turn off the water to it then take the arm and move it all the way down and turn on the water and you should hear it click than give it time for the first batch to get made be adviced to throw the first batch away somtimes there is dirt and little uglies in the first batch good luck!!!!
Posted on Aug 09, 2008
peyton32034
  • 410 Answers
SOURCE: Ice maker removal
first of all remove the ice bucket. then you will see a wiring cover on teh left hand wall just below teh icemaket. there is a rectangular hole in this cover. using a small precision scredriver carefullly insert into this hole and push up or and down to release a hidden clip. the trick is to pull on the wiring cover while you try to maneuver the clip. first time you do it it can be very frustrating but keep working at it and you will get it.
alternately you could just leave the Icemaker in place and use a hairdryer to melt the jammed ie out of the way. good luck peyton
Posted on Jan 28, 2009
  • 5677 Answers
SOURCE: want ice maker with crushed ice maytag
Try looking in your phonebook for Servall. It is a reputable appliance parts source. Or if you can check online for the Maytag website you can usually find the part yourself and order it or talk to customer service. Last, there are a number of online appliance parts companies which may sell genericparts for your unit.
Posted on May 19, 2009
philbran
  • 242 Answers
SOURCE: Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Posted on Jun 11, 2009
rickead1
  • 1998 Answers
SOURCE: maytag refrigerator ice maker opens and closes?
replace the icemaker you can order one directly from marcone or allbrandsppliance
Posted on May 18, 2010
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Maytag refrigerator MTB1504ARS runs continuously
It looks like you have a defrost problem. It could be blocked air vents but I think there is a problem with either the drfrost heater or defrost thermostat. It cound be the defrst timer or control but i would check the heater and defrost thermostat first.
Oct 04, 2014 | Maytag MTB1504ARS Top Freezer Refrigerator
Maytag MFI2665XE
The ice maker was an option that was installed where you bought the refrigerator. Most all ice makers work in a similar fashion. The device that tells when the ice tray is full may need an adjustment.
Sep 19, 2017 | Maytag Refrigerators
We are trading in our small MayTag refrigerator Model MTB1504AR made in Jul 2005 for a larger (22 cu ft) model. Can you tell me if the MTB1504AR was Energy Star Qualified?
I don't think so ... if your refrigerator is qualified , it must bear a yellow sticker with red stars of your rating on the front side itself.
Kindly rate my answer if you are satisfied or not. Thanks a lot . Good day to you . Deepak Richard
May 03, 2011 | Maytag MTB1504ARS Top Freezer Refrigerator
Phil
Jun 11, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
My maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Maytag Refrigerator Ice Maker
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Refrigerators
Open Questions:
Maytag MTB1504ARS Top Freezer Refrigerator Logo
12 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
