Question about Heat Controller RF-51-5 Thru-Wall/Window Air Conditioner
MY comfort aire rf 51-5" MAKES A NOISE LIKE A LEAF IS STUCK IN THE FAN BUT THERE ISNT ANY IDEAS ....ALSO HOW DO YOUTAKE OFF THE FRONT TO GET TO THE FAN THANK YOU
  • thumper106
    thumper106 Oct 14, 2013
    ONLY DOES THIS ON HIGH
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
It is due to air cut, it can not be fixed, but reduce by adding a therocol sheet in the air window
Posted on Oct 15, 2013
Buzzing noise in dash
I have had that happen two times: once, there was a coin stuck between the windshield and the front of the dash; the second time it was a leaf in the air vent fan. Good luck!
Apr 05, 2014 | 2004 Ford Expedition
Rattle
Usually it's the fan or fan motor, or the rotating motor making the noise. Usually you can pull it off or clean it...AND the bearings, which could be crudded up.
Dec 04, 2013 | Comfort Zone Cz488 Ceramic Oscillating...
Cabin fan makes noise at lowest setting. How to correct?
Either a bearing going bad or a leaf, stick stuck in fan cage take out fan and clean and lube or replace with new
Oct 14, 2013 | 2007 Chevrolet Uplander
Noisy fan ford falcon EF
Bearing have gone and extra draught is pushing it to one side a bit hence the noise unless you have a leaf up the pipe above the fan that i had before now ,but the recirculate was quite so yes i have had this before
Feb 15, 2012 | Cars & Trucks
When i turn my heater on (and also the ac) it makes a loud humming noise. as i turn it higher the noise gets louder. I have a 2001 chevy trailblazer.
It is possible that a stray leaf or piece of debris is stuck in the blower fan blades. This is more likely if the noise began suddenly. You will have to access the blower and remove it to inspect the blades. If their isn't an obvious debris problem, the blower fan bearing may be wearing out and getting noisy; although this noise would slowly get worse and worse every day.
Jan 24, 2011 | Chevrolet Blazer Cars & Trucks
Hey guys! My rf900 , when in idle, if I leave her for like, 5 minutes, stopped, the temp gauge will touch the first red indicator. (revs around 1k) Also when in heavy traffic, if I do lots of stops...
Flush the radiator. Use something like Prestone's radiator flush for cars. then refill with MOTORCYCLE COOLANT. this is important. the manual says you can use any coolant compatible with aluminum radiators. I did this and replaces 2 radiators before I figued it out. if this doesnt work, have the radiator tested. Also, I had a problem with the fan melting and not even knowing it. muzzy's makes a 6blade aluminum fan cheaper than the stock plastic replacement.
Aug 27, 2010 | 1994 Suzuki RF 900 R
Steady click fan noise 2007 Tucson
you have something stuck in the squirrel cage of the blower motor.All you need to do is drop the glove box open and look where the cabin air filter is,remove the cabin air filter and reach down there and pull the stuff out;its usually a leaf or napkin.
Jul 27, 2010 | 2007 Hyundai Tucson Limited
A noise has started coming from under my glove box. thi stops when i press in the air circulaion button and immediately after letting go of the circulation button it stats again?? any ideas
Could be something like a leaf stuck in the air system. I would pull out the cabin filter( under the hood, near the windshield on the passenger side) with a phillips screwdriver removed screw and pull out black plastic housing...removed cabin filter, and look inside area for any debrie. You will see a fan inside. Replace that filter every 15,000 or every year.
Jan 21, 2010 | 2001 Volkswagen Passat
Engine problems with mk2 fiat punto elx
that sounds like a clutch problem. get it checked asap because if that goes you may get stuck in netural and not go anywhere happened to me and it has not nice. if you start smelling a burning smell. that is defo your clutch
Nov 17, 2009 | 2006 Fiat 124
Heat Controller RF-51-5 Thru-Wall/Window Air Conditioner Logo
52 people viewed this question
Top Heat Controller Heating & Cooling Experts
jdthefixer
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you a Heat Controller Heating and Cooling Expert? Answer questions, earn points and help others
