Question about Emerson Mw9339sb Microwave Ovens
This microwave runs but does not heat up it started out it would heat up sometimes then it stopped all together
Tip
DANGER WARNING! Potential Hazard if your microwave was working and now doesn't...
If you have this model microwave and it was working fine, then one day it stopped heating items placed inside there are a handful of different issues that could be the problem. In my case it was intermittent, over a period of a few days it would sometimes work (heat) and sometimes not. NO MATTER if this is what your's is doing or if it stopped heating all together. If you decide to let it dry out, or not use it for a while to see if it was a one time occurrence, or whatever the reason, the first time you put something in and probably for the next 10 times at least (this assumes it starts to work again), make sure you are right there with it while it is cooking. Don't assume you can put something in, go do something and come back when the timer is beeping. There is a chance (as this happened to me) that your food inside will CATCH FIRE! Normal food item placed inside, no metal, nothing different than the numerous times before when this had been cooked but when we smelled smoke we came running. Fortunately it started and finished inside the microwave but that's not a guarantee, it could spread. Play it safe. Never had a problem like this before and never heard of a microwave cooking something until it caught on fire (especially since the time entered for the cook was 30 seconds) but it did.
on Sep 23, 2013 | GE JVM1850SMSS Microwave Oven
My GE jvm2070BH002 Microwave starts but stops.
Sounds like the control board. Not many parts in a microwave oven. That is the only one that generally goes intermt
Feb 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My Panasonic microwave, Dimension4, The Genius, will not keep running after start button is pushed. It runs for only two or three seconds.
There is a thermal fuse that monitors heat from the magnetron, sometimes becomes defective, the magnetron "heats food" filiment will open on occassion, if the exhaust fan is not running microwave will shutdown.
Mar 09, 2012 | Panasonic Microwave Ovens
Every thing seems to operate correctly but it does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;'';';';';
Jul 03, 2010 | Amana AMV5164BA Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
Frigidaire microwave stopped heating
The problem of not heating is most likely the door interlock switch. The 'primary' one goes bad the most often. On some microwaves all the interlock switches are in a cluster and must be replaced together and on other microwaves the switches are individual micro switches.
Oct 17, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
Emerson Mw9339sb Microwave Ovens Logo
19 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
