Question about HP Office Equipment & Supplies
Error 79 hp 3300 - HP Office Equipment & Supplies
    Guru:
  • 389 Answers
OK I had the hp error code 79 for HP 3300 problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Posted on Sep 14, 2009
HP 400 stuck initializing
79 is an firmware error. Try to update the firmware. You can find the file on HP website, on the Drivers and Support section. There must be also the procedure to execute the update.
May 29, 2014 | HP LaserJet Office Equipment & Supplies
Trying to receive fax but cant
yOU DO NOT SAY WHAT FAX MACHINE YOU HAVE.
tHERES A DETAILED TROUBLESHOOTING FOR HP LaserJet 3300 Series Printers - Troubleshooting a 79 Service Error AT
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette
Feb 25, 2014 | Office Equipment & Supplies
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
Dec 16, 2013 | HP DesignJet Office Equipment & Supplies
HP LaserJet M425dn MFP 79 Service Error
How To Troubleshoot HP 79 Error?
This is a fairly found as a common HP printers error which is usually caused by malformed PostScript documents in the HP printer. According to the study by a HP error 79 technical support professional team experts, printer shows a "79 Service Error" on the LCD display. HP service error 79 is a considered as a quite generic issue which is found on the HP LaserJet printer while working. Most of us face this same issue unexpectedly. But there are ways to get over with it:
What you need to have?
- Internet access.
-Admin account for the computers
Steps to resolve this HP error code 79
    ?In the very first step, you are needed to switch on the LaserJet Pro 400 printer.
    ?Ensure that the printer is properly connected to the internet. Users should be able to have a strong
    ?Ethernet cable connection running from the device to their modem or may even require to switch or a router.
    ?Now in the M401dn control panel/display section, click on the "Network" icon first.
    ?As per as study by HP error 79 tech support is concerned by a HP error 79 tech support technicians, verification of the IP address on the printer machine is necessary. Well, if it shows 192.168., then it clearly signifies that you are well connected to your home network. Else, a small check is needed to receive a symbol like 169.....
    ?Now step back to the home display section and then click on the "Settings" icon.
    ?Choose an updated LaserJet printer and then perform a check for all the firmware updates to ensure about all the latest updates.
    ?Continue the process by choosing a proper update and then click on the download and install button
    Fix your HP issues anytime with our HP professionals
    We deliver the best-in-class HP customer support service solutions for HP users across the world equipped with top-notch HP printer support solutions by applying the latest technologies to match users' need. Our HP printer support Toll-free 1-800-213-8289 number is all-time accessible for users across the world at our toll-free calling contact details to fix various critical types of HP printer problems affecting the performance of your HP printer. Prices are extremely feasible in nature.
Sep 16, 2013 | HP LaserJet Pro 400 MFP M425dn
My hp Laserjet 3330 Had error 79
Firmware error. Unplug the power cord. Wait 30 seconds. Plug it in, power it on. If the error comes back, you will have to upgrade the firmware.
May 20, 2010 | HP LaserJet 3330 All-In-One Printer
Error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Recommended action 49 and 79 Errors, Turn off then on The product has experienced an internal embedded software error. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Jul 02, 2009 | HP Laserjet M2727nf Multifunction Printer
Error code 79:04
From the service manual:
System Error: 79:04
Problem Description: Firmware Error.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer on again and check if the Error Code has disappeared.
If the Error Code reappears, check for a new Firmware release.
The firmware upgrade and tool can be found here.
Jun 16, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
My hp laserjet 3030 keeps reading 79 error power on power off
79 errors are often fatal. Your only hope is to get it back to READY, then update the firmware before it reverts back to 79 ERROR. The other option is to replace the formatter, but it would be about the same cost to replace the whole machine.
Apr 07, 2009 | HP LaserJet 3030 All-In-One Printer
Error 79
Error 79 -product has experienced an internal firmware error Solution-disconnect power cord wait at least 30second ,then reconnect the power cord wait for product to intialize.If error persisit upgrade firmware
Sep 28, 2007 | HP LaserJet 3015 All-In-One Printer
875 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
