Question about Toshiba 200 GB USB 2.0 PORTABLE EXTERNAL HARD DRIVE
How to unprotect toshiba 500 gb external hard drive
  • 1019 Answers
SOURCE: Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Posted on Feb 25, 2008
gpetti2009
  • 92 Answers
SOURCE: reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
Posted on Apr 08, 2009
paper bag
  • 72 Answers
SOURCE: My computer isn't recognizing my new Toshiba Roco
If it is new and has not worked at all, you should try using it on another computer that, if possible, has a different operating system. My first option would be to create a partition using a 3rd party partition creator.
Posted on Dec 26, 2009
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
lock123
  • 6831 Answers
SOURCE: Toshiba 320gb external drive is not detected by any laptop...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
No power signal in my external hard drive
Can you still read data from HD? Test USB port with an another cable and an another HD or some USB equipment you know are OK,
Mar 24, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
Can i attach an external usb hard drive to a toshiba lcd tv
The usb external hard drive was designed to work with windows operational system giving access to all the files, attaching the hardware would give limited use at best and may not respond.
Apr 22, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I reformat my toshiba canvio 500gb external hard drive for my macbook? If I go to disk utility and erase it, wont it erase the backup software as well?
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Dec 25, 2010 | Toshiba Canvio 500 GB USB 20 Portable...
My son knock my seagate 500gb external hard drive on the floor and now it just make a humming noise and stop what can i do
Most likely the read/write head on the arm assembly has touched the platter and /or jammed itself on the platter assemblies and is damaged beyond repair. The read/write heads on these unprotected hard drives is very fragile and cannot take any abuse whatsoever. There really is no magic fix unfortunately to mending physical damage. It is most likely that the drive is damaged beyond what the lay person is capable of fixing, in most cases these devices have to go to a company that specializes in data recovery and hard drive system rebuilds....both are usually expensive.
Jun 16, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Reformatting an external hard drive
Apr 08, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
How do I get the files from the WD external (500 GB) to my computer
In this case the MOST effective way is to try some data recovery program to see if it can help rescue your data on your WD external.
Jul 24, 2008 | Western Digital My Book Essential Edition...
Toshiba 200 GB USB 2.0 PORTABLE EXTERNAL HARD DRIVE Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
