Question about Samsung Heating & Cooling
Error code E 163 - Samsung Heating & Cooling
3 Suggested Answers
  • 207 Answers
SOURCE: Error Code 173, 192, 163
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center
Posted on May 22, 2008
  • 990 Answers
SOURCE: sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Posted on Feb 05, 2010
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Sep 16, 2010 | Sharp AR 163 Copier
Sharpe ar-163 with error code u-240
Feb 05, 2010 | Sharp AR 163 Copier
F4 error message. Cleaned out screen at water inlet and still get error message.
There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
It says there are error codes 163, 8611, and 163 time and date pop up but if you try and pass that it freezes and shuts down again. please help
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
Jun 14, 2009 | IBM ThinkPad 600X Notebook
May 22, 2008 | IBM ThinkPad 600X Notebook
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Heating & Cooling Logo
16 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
