Question about Gateway 831GM PC Desktop
Gateway 831GM Eratic Fan Noise
Ok, I have a Gateway 831GM with a loud rear system fan.
The fan is a 4pin 90mm hydrolic ATC brand. I opened the chasis and cleaned out all of the dust then noticed that the rear system fan was still eratic - fluctuating RPM's - higher then lower, slow then fast.
I ordered the exact fan then replaced the old fan.
The PC worked well for a little while; several hours, but it started the eratic RPM's again with the new fan.
Could this be a power supply problem, if so, if I have a bad power supply could the power supply have ruined the new fan? I hate to have to shotgun parts.
Thank you.
  • vannost Apr 24, 2009
    Hi
    Thanks for that great answer. I have a few follow up questions.
    The 4 pin to Molex connector - would the connector attach to the motherboard (male side) or the female end of the 4 pin connector?
    Also, is the temp sensor a chip on the motherboard or a FRU that I can order?
    Thank you.
  • 696 Answers
This can be caused by several things:
1. Bad temp sensor
2. Bad voltage, but that will usually cause the whole system to restart
3. Too low maximum temp setting inside the chassis(setting is in bios), often denote as max case temp.
One way to bypass the problem is rig the fan to a molex adapter with a variable voltage molex to 2/3/4pin fan connector and adjust the speed to the maximum quiet setting.
The 831's did run a bit warm so if the case temp setting is set to low it will fluxuate quite a bit. Try adjusting the max case temp up around 50c just to see if that does it, if it does either use the variable voltage dial solution or add a second case fan that's always on, prefferably a low RPM running direct off molex so it will reduce the average temp and therby the need of the monitored case fan to rev up.
Chris
Armor-IT
Posted on Apr 24, 2009
  • Chris
    Chris Apr 24, 2009
    It connects to the female end on the lead from the fan but will not allow RPM adjustments/control.
    Temp sensors vary but are generally attached permanently to the motherboard and must simply be disabled if they fail(not the safest solution). For a few extra bucks though you can get replacement/add on fans that include case temp sensors built onto the power lead which are a good idea.
    I have seen enough of these fail though that as a precaution my main PC has two after market exhaust fans and 4 intake fans which including the PS fan and Vid Card fan gives it a 1.5:1 intake to exhaust ratio, a ratio I have always favoured in gaming systems or systems than run 24/7
    ps. Never ever run an adapter from the Molex to a fan block connecter on the mobo as you could cause a nasty short and potentially fry the mobo.
    Glad the answer helped,
    Chris
Fan making loud humming noise
Take the fan, open it, use just one small motor oil drop into the fan axle.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Jan 30, 2014 | Gateway Computers & Internet
Gateway nv44 fan noise
What kind of noise? Does it click or rattle or is it whining really loudly?
Mar 03, 2013 | Gateway NV44 fan - NV44 laptop cpu cooling...
I had a fan making a clicking sound & a Friend cleaned it & now it turns on but nothing on the screen, what is messed up? where can I find parts to fix it? This is on my Gateway 831 Gm it has a...
Hi jdr_dlr519!
Pardon me.... but did your friend connected the monitor cable correctly on the system unit? Cleaning the fan will not break your computer... however, if he forgot to disconnect the power cables before opening the unit, it may do a damage.
Jul 20, 2011 | Gateway 831GM PC Desktop
I am trying to determine what cpu pentel 4 (D) 3.0
Gateway 831GM Pentel 4(D) is for socket 775
Jul 25, 2010 | Gateway 831GM PC Desktop
My computer started making a loud noise that will not stop. I am not sure if it is the fan or hard drive. The computer seems to be working fine. Any idea what could be making the noise?
In order to confirm the problem.. first of all turn off the pc and unplug the power cable from the back of the pc.... get a Philips head screw driver and open the chasis.... plug in the power cable and see where are you getting the noise from .... there are three fans namely one on the processor, the other a cooling fan and the last would be inside the power supply.. if its inside the power supply nothing can be done ... if its the cooling fan noise .... try to clean the vents or the cooling fan with the help of the dry cloth and if its the processor fan then its a serious issue ....
Apr 12, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Loud fan
Hello
I have a gforce 9600gt oc addition and that fan is loud beyound your wildest expectation, but although there is lots of utillities you can install to reduce fan speed thus reducing the noise, but can cause permanent harm to your system(it will most probably overheat). You can try blowing all the dust of the fan using compressed air to reduce the rolling resistance of the fan. You can find a fan speed utillity with the name of LG X110 fan utility from google, developed by msi, but i wount recomend it. Hope this can help you, please rate this
Best regards
Sep 26, 2009 | Gateway Computers & Internet
Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Aug 03, 2009 | GE Refrigerators
Gateway 7510GX CPU Fan noise
If this is a brand new laptop it would be still under warranty.
I suggest returning it to the supplier for repair under warranty because if you attempt to repair it you could void your warranty.
You should only attempt repairs after the warranty has expired.
Apr 06, 2009 | Gateway 7510GX Notebook
I replacement fan
They sell some things that you can put on the fan so it can run quietly without making any noise.
Oct 28, 2008 | Gateway 506GR PC Desktop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Gateway 831GM PC Desktop Logo
674 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
