Question about Blomberg DV16540 Dryer
Dryer turns on but does not dry clothes - Blomberg DV16540 Dryer
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Blomberg DV16540 Dryer Logo
Top Blomberg Dryers Experts
L Pfaff
L Pfaff
Dado
David Ellis Rhea
Are you a Blomberg Dryer Expert? Answer questions, earn points and help others
