Question about Schwinn 450 Elliptical Trainer
You start to pedal and about after 5 sec "workout paused" comes across the screen and all the read outs pause
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
Bike keeps pausing
Check your speed sensor
Dec 31, 2013 | Schwinn 150 Upright Bike
Hi, i have LG DVD Player DV6H, can i have region free code for this? Thanks.
Hi Coelhosc
For LG HD DV6H Media Player
1. Start DVD with no disk, wait for no disk in display.
2. Press "0" zero for 5 to 10 sec till screen appear
3. Press pause
4. Press "0" for 5 sec (both setting must be "0" for region free)
5. Press pause again.
All ready to go.
Sep 10, 2011 | LG DVD 6053 DVD Player
How can you extend the time of the pulse from 5 sec to 60 sec on the mk111
On that model, the pulse is only adjustable up to 5 seconds. The pause between pulses can be adjusted to 60 seconds maximum.
There are 2 adjustment screws on the circuit board, A is the pulse time, B is the pause time.
Dec 02, 2010 | Velleman Interval Timer # MK 111
How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Aug 01, 2009 | Samsung Propel A767 Cell Phone
Check engine light on 1998 Z3 BMW
BMW engine light
Comes on if DME engine management system self diagnostic fault detected. Will stay on until codes are called up and memory erased.
With OBD read the code as follows. Turn on ignition key, press accelerator pedal to the floor five times within 5 seconds. The check engine light will remain on for 5 sec , blik off, come on for 2,5 sec, go off for 2,5 sec and fault code will begin to flash. If more than one fault exist 2nd fault code will be separated by 2,5 sec pause. after fault codes there will be a 0.5 sec flash and light will remain off. to read codes again do procedure again.
Canceling of codes. make sure fault code is present (short blink and light goes out for long period), depress throttle pedal for at least 10 sec. read fault codes again and check for code 1444 (no faults stored.)
Check also the following, fuel pump, oxygen sensor, fuel injectors, engine coolant temp sensor, idle speed control valve, mass airflow sensor and too many other things.
Jun 16, 2009 | 1998 BMW Z3 Roadster
The engine light recently came on and now the engine spurts at acceleration.BMW328
when the engine light comes on the defect on the engine can be a blocked exhaust system or an air leak to the manifold. the oxygen senser monitors the runnig condition of the car and will inform you that the engine is not run correctly. diagnostic can tel you the defect
Jun 13, 2009 | 1997 BMW 328
Check engine light
BMW engine light
Apr 12, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Printing but not able to read bar code with scanner
make the pause test (press pause and turn on) press Pause , 5 sec. if print qualiti is ok and you dont see some lines across the print, the problem is not the printer.
if you see some withe lines across the print, you need to replace the print head.
Apr 15, 2008 | Zebra Z4Mplus Label Printer
Schwinn 450 Elliptical Trainer Logo
60 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
