Question about Sunbeam 805810 HeatSense Heating Pad Heater
Sunbeam heating pad cat95c
Heating pad won't turn on, it is flashing F. I tried unplugging from the pad but it still won't turn on. I've only had it for three months and it was over $30 at CVS pharmacy. I can't take it back because I am disabled with no transportation.
5 Suggested Answers
SOURCE: F2 Fault Code On Heating Pad
I am trying something now as I was told F2 requires you to check the blanket for wear and tear and plug it back in. 3 times doing this should be sufficient. If it still reads F2 it's "gone" Ours is new so it shouldn't be "gone" but here's what I found...Where the plug goes into the blanket there are 4 holes for 4 silver pins. I noticed the 3rd pin was a bit lower than the other 3. It will not move up with pliers so don't force it just return it. check there
Posted on Feb 02, 2010
  • 4736 Answers
SOURCE: I have have my sunbeam
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Posted on Feb 17, 2011
lynnsspace
SOURCE: Have heating pad model 809.
We have so many of these pads (now only) after the control part went to F1 and F2. My husband found the problem by taking the controler apart. Sadly what Sunbeam does is "pot" the wires. Meaning they put them into some plastic stuff to keep them from touching. But by doing this they leave the wire that makes the thing work to be the weak link that gets weakened even more by use and moving and adjusting the thing. It eventually breaks and he found there is no easy way to solder it back to the "potted" wires. It just leaves a short stub out of the pot. So if anyone knows how to purchase just the cord or fix it the heat pad would probably work just fine. So now we know what F1 and F2 actually means.
Posted on Mar 29, 2012
grannywindu7
SOURCE: Sunbeam dual control heated mattress
I have older sunbeam duel control matress pad. the control is simple with a dial that turnes for low or higher settings. it shows a red line that is small for low and gets thicker as the setting gets higher. there is a button for on and off. I set up the cover and turned on. the green on lite is flashing and there is no heat i do have it on high and it now will not turn off by the button.
Posted on Jan 25, 2013
Sunbeam heating pad flashing F
Unfortunately I bought this heating pad three months ago and it too has an F in the display which I think means 'failure' but I do not know why. Also this is brand new and has worked fine for three months. Now what?
Does anyone out there have a comment to help me and this original person asking this question?
Jan 04, 2014 | Sunbeam Xpress Heat Heating Pad 2013-912
Electric blanket flashing f won't stop sunbeam
Hello vinrocof - Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness or damaged cord. I would suggest contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FEF336BC Electric Kitchen Range
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
I just moved to New Zealand
It seems like the AC converter may not have the ability to procduce enough current. Check the wattage of the heat pad then see how many watts the converter can produce. (watts = volts x amps). You can buy a good Sunbeam electric blanket in NZ for about $110NZ, a capable AC converter may cost you considably more. Enjoy your stay in NZ!
Jun 19, 2009 | Sunbeam SG7621SP Grill
New heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Sunbeam 805810 HeatSense Heating Pad Heater Logo
404 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
