Indesit wil1635 Bad shaking when spinning
2 Suggested Answers
jason0110
  • 66 Answers
SOURCE: indesit w123 shaking
hi your machine is either out of balance , or a support leg may have gone weak.or a spring or worse case your bearings and spider need replacing
Posted on Jul 14, 2008
Indesit idv65(uk) making humming noise - motor not starting - replaced capacitor and belt
if the motor doesn't start and makes a humming sound you either have something stuck in the blower wheel from starting the dryer with the lint filter out or the motor is bad,so either something is jammed and stopping the motor from spinning or the motor is bad.
Oct 04, 2017 | Indesit Dryers
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Noisy bearings on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jun 07, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Indesit w123 shaking
I had the same problem the drum when in spin cycle with the machine almost walked out the door shaking violently as if it was possessed. Check the drum on the inside of machine as most times it has some kind of screw to hold it in place for transporting etc. I did find on the other cycles it worked fine except for the spin cycle, and l have this machine in my caravan near my bed so you can imagine the ferocious noise and how scary it was, and it was a simple error on our behalf. I hope this resolves your problem. Kind Regards Karen.
Jun 24, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine will not drain and carry on with full cycle
Same problem - changed module with no result. Looks like the water temperature thermistor...
Jun 12, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
