Question about Garden
Karcher 6.85 m keeps blowing 13 amp fuse as soon as iswitch it on
jerryg50
  • 1689 Answers
SOURCE: AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Posted on Apr 25, 2008
bigg t
  • 640 Answers
SOURCE: break / hazard light fuses keep blowing
check both brake lights for moisture getting into them.
Posted on May 26, 2008
  • 92 Answers
SOURCE: Karcher KB3030 Pressure Washer
Dear doc doz,
Most probably you have the spill valve stuck in a position that keeps the machine off. This could happen for various reasons. It could get stuck by using plenty detergents or chemicals, without rinsing the machine afterwards. It could happen by leaving the machine under pressure for a long time. Most probably (with all respect) you used to store the machine when not in use, with the pressure still in the system. To fix this problem the machine has to be opened. When you come to the spill valve, you can bypass the micro switch and if the machine works, then it is the spill valve. Most probably it is the spill valve and you have not much expencies to fix the machine. If you do not know how to fix it yourself, I suggest that you take it to an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 16 Answers
http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Hi You can refer to my detailed solution above...if you still have issues please feel free to contact.
Thanks
Posted on Dec 16, 2008
  • 109 Answers
SOURCE: fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Posted on Jun 29, 2009
No. 13 fuse keeps blowing in my 2000 mit galant. what does it operate?
#13 looks to be the anti-theft fuse. http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/dc457db.gif
Jan 04, 2018 | Cars & Trucks
My Karcher MX720 pressure cleaner keeps tripping the mains power.
Jeff, the specs say it is 230 volt, 16 amp minimum, start up would be more, probably minimum 20 amp.or larger, check your manual. Are you using a small gage/ low capacity extension cord this could blow a breaker or may have an internal short have checked by a Karcher repair center. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Any idea why my new 13 amp pressure washer is tripping 15 amp circuit...
http://www.garagejournal.com/forum/showthread.php?t=203916
http://www.electriciansforums.co.uk/electrical-forum-general-electrical-forum/54098-problem-pressure-washer.html
Jun 17, 2016 | Karcher Garden
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Lowvoltage fuse keeps blowing
the contactor on the condensor if it blows on a call for cool.
Nov 27, 2012 | Gibson Nordyne GR6GD-X24K045C 2 Ton 13...
Blowing fuse
Check for bad caps or diodes. Look for anything discolored or burned.
Dec 11, 2008 | Memorex MT1131 13" TV
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Pressure washer karcher
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Mar 26, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
