Question about Kingston Electronics - Others
Hey there, this morning my Kingston usb flash drive fell into a cup of coffee. I removed the flash drive immediately and dried off the excess water. I then proceeded to insert it into my laptop, it worked for a while before I received a message saying that the drive has malfunctioned and cannot be recognised. I now realize that I shouldn't have inserted the drive into the laptop before it had dried completely. Is there any way that I may salvage the drive?
  • 13,190 Answers
Pack it in rice for a few days and try again. might work who knows. uncooked rice
Posted on Jun 17, 2017
t34mod85
  • 35 Answers
SOURCE: i inserted my Apcer USB 1gb flash drive, it was
Is there anything on the disk it self? If there is/was a virus on the disk, it could have left a 'autorun.inf' file on it ... So try Right-click and select explore. Or try to access it via the Total Commander
If that doesn't work, try formatting the disk.
This is an often problem with most low-end flash disks.
Did you receive some software with that disk?
Posted on Mar 18, 2009
SOURCE: My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Posted on Jun 07, 2009
  • 13 Answers
SOURCE: USB drive is inserted but reports that disk is not inserted
With the thumb drive inserted in the computer you might try right clicking on “My computer” go to manage and under storage go to disk management. See if your computer reports information on you drive. If not the drive may be damaged or the driver may need to be reloaded
Posted on Jun 20, 2009
  • 111 Answers
SOURCE: usb devics not recognized
try it to a known good USB port. if still unsuccessful connect it to another PC that has a known good USB port. if still unable to work. you might have a bad USB stick..
Hope it helps!
Posted on Feb 18, 2010
  • 8 Answers
SOURCE: Bought a maxell 8gb usb flash drive. When I try to...
By trying to use it I take that to mean you go to My Computer and select the drive you believe it to be.
Try going to My Computer with the flash drive unplugged and then plug it in while watching My Computer for a new drive letter to appear. That will be the one to use.
If you select the wrong one you will get the message you are experiencing.
Posted on May 21, 2010
How safe are keureg coffee makers as far as mold building in the resovier.
Make a cup of coffee then immediately remove the k-cup, notice how the cup is dry? Coffee doesn't enter the reservoir, it leaves the cup through a separate tube at the bottom. No moisture means no mold buildup, but if you leave a used k-cup in the coffee maker for a week or two you're on your own! :D
Sep 29, 2014 | Keurig Coffee Makers & Espresso Machines
My pen drive is fell into water ...light s glowing but now it s not working how to use plz tell
Dry the flash drive as much as possible with a piece of paper towel to absorb excess moisture. Gently pry open the case of the flash drive if possible, using a small flat-blade screwdriver to separate the two halves of the case. This is not essential, but will cut the drying time and will help to limit corrosion. Dry the inside of the case as much as possible with the paper towel. Pour some uncooked rice into a small plastic bag, and then place the flash drive in the bag and seal. Place the bag in a warm, dry place for at least 24-hours. The rice draws out and absorbs any moisture present, speeding up the drying time and ensuring the drive is completely dry. Check the drive after 24 hours. If you can see any moisture, leave the board for 24 hours and repeat until the board is completely dry. Reassemble the case, ensuring the two halves are tight shut. Use a small spot of glue to hold the two halves together securely if necessary. You can then use the flash drive as normal.
Mar 14, 2013 | Electronics - Others
I have kingston datatraveller 100 G2 4gb its internal software had been gone since it had fell into water so plzz tell me link to download software
if it has fallen into water it might have been damaged beyond repair
the only thing you could try is to dry it out
leave it in a dry place
hope this helps
Sep 15, 2012 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Turned on, heard clicking, now keeps blowing GFI and won't work
Hello Rightorl...
Everythig made by man is repairable... and to
MERCILESSLY drive the point home... even
AMAZON carries part for your "B70"... (eBay too).
Just the slightest amount of conductivity
is enough to trip a GROUND FAULT... So
you are not necessarily looking for NAIGRA Falls.
Amazon...
1 16 of 291 results for keurig parts
I believe if you search online
You can even find a KEURIG Company PART supplier:
Keurig Parts Keurig Coffee Maker Replacement Parts
- Frankly...
I love coffee ... (excessively strong)
((life is short... and I am old))... Not withstanding
my POT- FILLER... CHEMEX... smart-home daily
automatic brewing capability...
I have reverted to the camp-fire brewing method...
BOILING water, removed from heat, IMMEDIATELY
gets a mega dose of freshly/finely ground PETE's
(never to see heat again it is COLD filtered through
a Melitta #6 and stored in the refrigerator...
Drained into a three quart carafe...
Grounds are immediately distributed to the redwoods...
When my sisty wants hot coffee... Microwave 90 seconds
(taste is ALWAYS AWESOME)...
Else the BOSS (she who must be obeyed) & I enjoy
our iced LATTE Coffees in the morning...
If it is too cold... we build a FIRE first.
Life is good (12 cups at a time).
Carnac the Magnificent
Oct 22, 2017 | Keurig Platinum B70 Coffee Maker
Water Damage to USB Flash Drive
The problem is very bad. In my openion there is only one solution with this problem. all you need to do is to remove its plastic casing and then put your USB into thinner ( A liquid that can be found at paint stores). Then let it get dry for 5 to 6 hours. And you are done. now connect it to your pc and get your data. Don't forget to rate the solution. Thanks!
Feb 28, 2009 | SanDisk Open Box 1GB Cruzer Mini...
Kingston DT1000 pendrive was not detected in computer
hey my 8gb kingston pen drive is not detecting at any that is out of warranty any tricks to make it work. i was tried all my level best but that is not detecting............. so any chance get that back
Feb 04, 2009 | Transcend (589307) Media
4 MB Data Traveler freezes my computer
Hi lassiebee,
Try the USB drive in other USB ports on the computer. Are you using a USB mouse and USB keyboard?
Kingston Tech Support
Jan 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Need to replace water carafe to Starbucks Barista Araoma 12-Cup Coffee Pot
I have the same problem, but have not been able to find a new carafe, so far.
Jun 10, 2008 | Starbucks Barista Quattro Coffee Maker
Electronics - Others Logo
689 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
