Question about Samsung MW6572W/MW6573G Microwave Oven
How many cubic inches is the samsung microwave model mw6572w
How do i turn demo mode off on model mw6573g samsung microwave
Press " My Settings" and the number 6 and then the number 1 or 2 to turn off the demo mode
Nov 18, 2016 | Samsung MW6572W/MW6573G Microwave Oven
How many cubic ft in a microwave that is 15x30x15 3/4?
12x12x12= 1728 cubic inches= 1 cubic foot
15x30x15.75=7087.5 cubic inches.
4.1 is the answer.
Feb 12, 2016 | GE SpaceMaker Microwave Ovens
How many cubic ft. in a Kenmore microwave over stove model # 665-61612100
Just measure the inside dimensions of the unit in inches. Get the length, width and height then use this formula: (L x W x H)/12 = Cubic Feet
Feb 26, 2015 | Kenmore Microwave Ovens
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Sep 12, 2014 | General Electric Microwave Ovens
Convert cubic inches to cubic feet
Since there are 12 inches in a foot, there are 12x12x12 or 1728 cubic inches in a cubic foot.
Dividing 1404.4921 by 1728 gives about 0.8128 cubic feet.
Mar 16, 2014 | Microwave Ovens
Model 56-4677
Measure the width, depth, and height in inches of the interior cavity.
Multiply the length by the width by the height to get the total in cubic inches.
Divide the cubic inches by 1,728.
The resulting number will be your microwave's capacity in cubic feet.
Jun 05, 2013 | Microwave Ovens
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
Mar 19, 2011 | Microwave Ovens
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Which bulb do I need for Samsung MW6573G microwave
You can see a photo of it here: http://www.samsungparts.com/images/parts/tv/4713-001012.jpg It's an assembly, and not meant to be separated. But if you have a clean socket, you can use a standard 40W appliance bulb that will fit it. Otherwise, you can get the original bulb assembly at that same site if you prefer. It's part # 4713-001012.
Dec 13, 2006 | Samsung MW6572W/MW6573G Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
