Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Can you bypass the bi-metal thermal cutoff? I have replaced this switch 5 times, and now i'm replacing it again. the tco only lasted 2 weeks. (kitchen aid dishwasher)
3 Suggested Answers
  • 105 Answers
SOURCE: I am trying to replace the soap dispenser on my
As I look at the pictoral, it seems there are twelve screws that hold the inner door to the outer door. Youmust remove these and then separate the door parts. Then you will see the screws that hold the dispenser in place from inside the door.
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Dryer wouldn't work last week. Found the Thermal Fuse with no continuity and replaced it. After drying one load of clothes yesterday, dryer won't work again. I suspect the thermal fuse again. What else ...
Or your breaker. The dryer will work just won't heat with the thermal cutoffs or element or the breaker. Dryer won't do anything if the thermal fuse is bad. You might also want to check the outlet from L1 to N and L2 to N for 110 on each side. Good luck.
Aug 22, 2010 | Whirlpool Dryers
BI METAL THERMAL CUT OFF SWITCH KEEPS BLOWING.
You might have debris clogging the drain/disposal. My wife just tried to wash labels off of some old jars, the paper is stuck in the drain and my TCO is blown.
Jun 04, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kenmore dryer Model 110.86982 Year 1989 does not heat
If you bypass the hi limit thermostat you will blow your thermal fuse within minutes. The hi limit thermostat is a bi-metal thermostat which warps when heated to kill power to the element. If its bypassed then the element will not turn off.....which will in turn blow your thermal fuse which is rated at a higher temp than the hi limit. So unfortunately it will not work.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Dryers
I am having trouble with it will be working fine for about a week then it will just kick off
sounds like the bi- metal thermo-stat switch puts in a week, then takes a little time off,now what's the matter with that, replace switch or if you're mechanically inclined you could clean and recalibrate the bi-metal switch
Jan 30, 2010 | Heating & Cooling
Oven will not heat after auto clean
you have a blown tco. Thermal cutoff....it is located in the back of your oven. connected by two wires usually a orange and a red. you can try sticking it in the freezer overnight some of the tco are resetable but they have to be frozen. then tape on the back of it with a screw driver a few times. if you have a multimeter check to see if the continuity comes back. if it does not replace it with a new one. MAKE SURE YOU TURN THE POWER OFF FIRST.
Dec 28, 2009 | Whirlpool Kitchen Ranges
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Iron won't heat up
well its had it chuck it out
Jul 18, 2008 | Audio Players & Recorders
Lakewook oil filled radiator heater
Here is your problem and yes it can be fixed.
More than likely your thermal cutoff tripped because your heater got too hot.
Solution:
1. Unplug unit.
2. remove front support feet and screw underneath face plate will slide off.
3. You will see the heating element, a white wire is coming out of it. There is a white sleeve on the wire tucked up into the element. Pull the wire out and slide sleeve off to expose the thermal switch labeled (S.W.C. sw-120t ect.) You can google it to learn more about the cutoff. If you know how you can test the cutoff with a ammeter or voltmeter, If you don't google how to test electrical systems. Remember "first do no harm"
4.
a. If you can replace the cutoff do so (this is the recommended way)
b. If you don't want to replace it cut the cutoff out and solder the wires back together. (be warned that this will bypass the safety system) If you do this be careful to not leave your radiator unattended.
5. After soldering the wire, taping it will electrical tape. Replace face plate from step 1 and 2 and your heater will work.
P.s. If your heater is still under warranty just contact lakewood.
Jan 20, 2008 | Lakewood (5500) Oil Filled Radiator Heater
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
42 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
