Question about Pioneer VSX-D810S Receiver
Keeps shutting hi i have some kind of weird issue with my receiver i put it on play some music for about 1 min it starts to sound like a freaking radio and really loud! and after that it shuts down but not intierly the display is still on just the ound that dies and if you wait the strange noice comes back so soon i put some bass on it hapends i tried to remove the bass from the receiver and use my EQ still same i have changed the Fuse but i can only find 1 fuse So the question is is the another fuse that is hidden i would be really happy if you can help me with this
  • 4 Answers
SOURCE: PROBLEM WITH MY JVC RX-3 RECEIVER!!
Is this a Pioneer receiver or a JVC? Either way, if you have "had it for years", replace it. You will be surprised at the price now a days. Gas is up, but electronic equipment is usually a good buy.
Posted on Jun 12, 2008
  • 336 Answers
SOURCE: Pioneer VSX-35TX , "Power Off Message" , will not stay on.
It's probably going to need output transistors and some resistors, it's a job for a technician. A rough estimate on price is $100 to $130 (that's parts and labor). Before the smoke it may have only needed repair of bad connections.
Posted on Mar 08, 2009
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
SOURCE: pioneer vsx-516 6.1 channels
Check the speakers one by one maybe there is one bad or almost damaged
Posted on Jun 06, 2009
  • 233 Answers
SOURCE: Pioneer VSX-D511 Comes up with AMP ERROR and shuts down
I must agree that if the fuses are open and you replace them that your problem maybe fixed. If you can remove the fuse, I recommend taking it to a RadioShack and see if someone there can figure out what it is. I am going to assume that the fuse should be a 250 V. If you can find one that matches the same appearance, go with the smallest aperage rating you can find. Go with this route only if the person can not tell you exactly what it is you need. Be sure to match the type of fuse if you can see inside it like in the case of a glass fuse. Some are slow-blow fuses and some are fast-blow. If you are uncertain your safest bet is to use a fast-blow with a real low amp rating for the voltage you are using. If the amp rating is too low, it may run fine at lower volumes and pop when you turn it up. If I could physically see the fuse, I would probably be able to tell you what it was and what you needed to replace it with.
Weird siren type sounds on the my 2006 Honda accord factory radio
Evil works in deceptive ways............. Just kidding, dude. I honestly have never heard of anything like this. Almost gotta be a wiring harness issue. If it were fuse-related, the radio would either work or not. I'm totally puzzled. Let me know when/if you figure it out. Best wishes.....
JB
Jan 17, 2018 | Honda Accord Cars & Trucks
Weird problem that no one can figure out please read and help
Should have had it towed to a repair shop
No one on the phone or over the internet can
diagnose an issue like that
Dec 11, 2012 | 2001 Ford Escape
When i turn on my mp3 player the sandisk screen keeps repeating and doesn't go into my options (music radio video etc) Help me asap as I'm heading to the gym in 1 hour and need my music! mandy
Hi, Shut it down for 30 mins and put it on back. If it does not work that way, that means it is affected by Virus, and will need to be flashed to play normal again.
You can use this link to see more about flashing :
hubpages.com/hub/How-to-Flash-your-cell-phone,
and
unlocktotalk.com/CellPhoneStores/index.php.
Take care.
May 19, 2010 | Audio Players & Recorders
Sounds coming from desktop
There may be several reasons for this like software conflict or may be a hardware issue.
Kindly let me know when desktop produces weird sound, I mean does this happen when you open any application or something..
But in the meanwhile, you can try the following :-
Step 1 - If you are technically sound then try to open computer tower,open sound card from the slot and put back in.
Restart your machine and check results,Kindly post your results..
Hope it helps !
Thanks
Oct 06, 2009 | Computers & Internet
Receiver keeps shutting off after 3 seconds. what
Be sure the face is secure, and there is no dirt in the connection on the face, and head unit.
Sha'ul
Jun 27, 2009 | Harman Kardon AVR 120 Receiver
Ps3 plays for about 10 -15 mins than freezes than...
Confirmed that this was an issue with the disk. I can't believe I got two defective copies!
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Pioneer VSX-D810S Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
