Question about Cycling
My scooter starts and runs in idle, when i barely give it gas, it stalls
  • 7 Answers
SOURCE: Hard starting when cold, runs rough at idle and any steady speed.
Your carburetors need to be cleaned. The pilot jets are at least partially plugged.
If you are comfortable doing this yourself, you need to remove the seats, fuel tank, and air induction system before you will be able to get the carbs out. Be carefull when removing the fuel tank, there is a wire harness that will need to be un plugged from it to remove it. The wire harness plug runs under the plastic tray under the seat. There are 3 plastic rivits that will need to be removed to get to the plug. The carbs come out as a pair, and can be tough to get back in the boots.
You need to remove the float bowls, remove the jets, and blow carb cleaner and compressed air through them all. The pilot jets are most likely the only culprit, but you might as well clean everything if your going to all the trouble. You should also blow carb cleaner and compressed air through all of the other passages while your at it. Make sure that you can see through the jets and there is no debris left in them. Make sure to clean the floats, needle valves, and float bowls as well.
Then re-assemble
This happens when the bike sits for long periods. The fuel we get now days has a very short shelf life before it goes bad. Fuel oxydizes over time, and it happens even faster in a small amount that is vented which is exactly as it is when its in the carburetors of a motorcycle. When fuel oxydizes and evaporates, it leaves a gummy mess behind. The pilot jets are the smallest passages that sit in the fuel, so they naturally plug first.
You can prevent this by keeping fuel stabilizer in your fuel when ever the bike will be sitting for long periods of time. Myself personally, when I store one for the winter, I like to leave the carbs empty.
Posted on Nov 26, 2008
SOURCE: 50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Posted on May 19, 2009
  • 3567 Answers
SOURCE: I have a Roketa 150cc Sicily Scooter (2006). It
Here's the deal. I have never even heard of your bike brand but I have 18 years in bike repair. If you promise not to give me anything less than a "helpful" rating I will tell you how to do the fix based on the assumption that the bike has a standard carb and not a CV carb. The standard carb has a top "cap" that unscrews from the center of the carb body.
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine. Now unscrew the top cap and pull the slide out of the throat of the carb. When you re-install the slide, be sure the long notch on the side of the slide lines up with the small pin inside the throat of the carb.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Posted on Jun 09, 2009
pippall
  • 1486 Answers
SOURCE: Pontiac G6 2005 - starts then stalls immediately
Chage the throtle possition senser.
Posted on Jul 03, 2009
  • 48 Answers
SOURCE: 96 jeep grand cherokee starts but wont idle
CHECK FUEL REGULATOR ON FUEL INJECTOR RAIL,&ALSO FUEL PUMP, CHARLIE
Posted on Feb 22, 2010
My 50cc kymco scooter starts but when you pull the throttle back it cuts out
Hi, Christopher and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike idles perfect but dies when given the slightest amount of throttle 93...
starts idles stalls giving gas Scooter Doc Forum
scooter dies if give it throttle
http://www.scootermasters.com/manuals/kymco%20People%2050-complete.pdf
Aug 27, 2016 | Kymco Motorcycles
Scooter has 40 original miles.New,old gas, I put innew gas. It starts,idles only, if I give it gas it stalls and won't run..
Hi, Rick if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.
How to clean carburetor in 15 minutes
Nov 25, 2015 | GAS Motorcycles
1997 saturn stalls when starts rough idle will stay running if you give more gas
Check your oil! then check for fuel pressure.I bet you're low or out of oil.
Sep 19, 2014 | 1997 Saturn SL
Stalls after start up, Stalls when braking, then runs fine after a few minutes
Check the ECU engine temperature sensor. If it thinks the engine is hot, it will struggle to run when cold.
Mar 06, 2014 | Volkswagen Beetle Cars & Trucks
2005 Honda Metropolitan stalls with throttle
Hi, Snoopyfan6 and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
urbanscootin com Honda Metropolitan Scooter Forum View topic 2006 metro...
2005 Honda Metropolitan Scooter Rough Start and No Power
Honda CH80 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CHF50 2007 Metropolitan Owner Manual
May 08, 2011 | 2005 Honda Metropolitan Base
Scooter starts but stalls after a few seconds. It has been stored for a few months.
Hi, Anonymous if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
For more information about your question please visit the website below. Good luck and have a nice day.2012 Tao Tao 50cc scooter BMW C1 scooter stall at idle after normal start FOUND IT
My chinese scooter wont idle or start Check the fuel petcock
http://www.benelli-scooters.de/pdf/BA_Benelli_Velvet125.pdf
Benelli Velvet 150 2014 service manual DOWNLOAD FREE FULLMANUALS COM
May 20, 2010 | 2008 Benelli Velvet 150
I have to give gas to start if not the car stalls
need to have a fuel pressure test also make sure egr is not open at idle car wont run with egr open at idle
Oct 20, 2009 | 1997 Buick Century
Mar 14, 2009 | Toys
Pioneer eclipse buffer , hard starting, barely idles, stalls ?
My brother does floors and I used to help him work on them.When we had that problem we either had to replace bent valves or replace a bent rod and adjust rocker arms
Dec 22, 2008 | Eclipse 5440
Cycling Logo
15 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
