No picture, only sound
Philips 32PF9731D this is my 2nd tv, the first one lasted 7 days until the display went. i got another brand new tv and 30 days later, the same problem, no picture. the company took the 1st one away and only told us that there was a problem but they did not say what.
  • 3 more comments
  • Anonymous Nov 12, 2007
    moved wires
  • kayh Nov 13, 2007
    tv was working fine one minute, the next, picture was gone, sound only. need to know if it is worth it to have it repaired? About 2.5 years old. Where do we take it? We called 2 tv repair stores, but they said they were unable to get any dell parts! HELP
  • Anonymous Oct 10, 2008
    I have same problem too
  • Anonymous Oct 28, 2008
    I have had my tv for just under two years and I have the same problem. No solutions.
    LG 26 LCD TV
I had this same problem. I found a replacement board ( I think the right board). I changed it out and it worked fine for about 2 months. Then same problem happened again. This tv is junk.
Posted on Nov 06, 2008
I would suggest the inverter pcb requires replacing.
Posted on Sep 25, 2007
I bought a Philips HTL2161B and it worked fine the day i got it, I had it turned off until the following evening, I went to watch TV and I had no sound from the bar, I am running optical.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 18, 2016 | Philips Audio Players & Recorders
I have a 42PFL3403 model (42"). Was bought brand new. After a few months, started with problems. The image went off (sound OK). At the begining was enough to turn off and turn it on again. With the...
This tv it new still under a year old?Yes.Tries take Philips warrenty repair.The tv problems,to the tv are the causes of the tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 23, 2011 | Philips 42PFL3403 42 in. TV
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
Picture went blank. Still have sound. What is wrong?
When was the last time,this tv the projection lamp was replaced?The projection lamp in the tv now,has not been replaced the last 1 1/2 or 2 years.The tv been on and watches 4 or 5 hours a day.The projection lamp life span is over.Require a new projection lamp.
Aug 11, 2010 | Philips 55PW9363 55" Rear Projection...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Just purchased a 42" Philips 42PFL7403D/27. Upon initial setup, I hooked my wires correctly, plugged the TV in, and I get sound, but no picture. I can not get ANY picture at all, even menu screens. How...
if you cannot get any picture at all, even the menu screens, then the set is defective.
My experience with Philips TVs was very similar, mine failed with one day, I exchanged that one, then the next one lasted about two years before failing again. My advice would be to exchange yours for a more reliable brand if you can.
Oct 19, 2009 | Philips 42PFL7403D/27 42 in. LCD TV
No picture, sound ok
you need a new flyback.
that is the problem.
Nov 11, 2007 | Philips 60PP9202 60" Rear Projection...
Dead Phillips 36PT842H
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jun 03, 2017 | Philips 36PT842H 36" TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
