Question about EnGenius Ens200 Outdoor High Power Client Bridge/access Point 400mw
How do I install a ENS200 long-range wireless outdoor bridge
    Genius:
  • 1,061 Answers
Http://www.smallnetbuilder.com/wireless/wireless-reviews/32008-engenius-ens200-long-range-wireless-80211n-24ghz-outdoor-bridgeap-reviewed?start=2
Posted on May 24, 2014
ENS202 installation and setup
It's a bridge. Are you sure it's not being found? Or is it simply extending your wireless network correctly and you only see one network? Bridges and APs usually have separate IPs, but the same network SSID is broadcast from them.
Mar 23, 2014 | EnGenius Outdoor 2.4ghz Wireless N300...
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
I am having Wirless A/G Outdoor AP/Bridge "DWL-7700AP" how to configur with Direct ADSL line 192.168.0.50 d-Link IP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
If still not able to access it then you need to reset it for that press RESET button for 10 seconds it is in back side of router.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
WAN settings are your internet service provider settings if you want to know wireless settings then click on wireless then you can find your wireless settings .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 19, 2010 | D-Link DWL-7700AP AirPremier Wireless AG...
Netgear WGX102 Powerline HomePlug wireless ethernet bridge dead
My friend, reward your year of hard work with a new router. Yours is dead.
Dec 11, 2009 | NetGear WL |WGX102 RANGE EXTEND R Bridge
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface Dot11Radio0
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
authentication key-management wpa
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
Hello, I currently use a Belkin F5D8631 as my Modem Router. I have a spare Belkin F5D7633. Can I use the 7633 as a repeater/bridge to extend my wireless range? If so, how?! Thank you
It will not extend your wireless range. If you connect your spare Belkin F5D7633 to your Belkin F5D8631, one of them would have to be set to "bridge mode" or a pass through modem so that there will be no conflicts as to which modem will receive the ip address from the network. If you set your modem/router to bridge mode, it would disable its wireless function because it will only be a pass-through device.
If you want some tips on how to improve your wireless range, check out this site http://www.microsoft.com/athome/moredone/wirelesstips.mspx. Hope this helps.
Apr 22, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Unable to get my WET54G up and running
Make sure that you routers IP range is setup to handle the IP address of your PC.
Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
EnGenius Ens200 Outdoor High Power Client Bridge/access Point 400mw Logo
103 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
