Question about Weiser Lock POWERBOLT ELEC DEADBOLT
The weisser upon pressing the lock button fully extends the bolt- but when we enter the key less code, the bolt does not fully retract and you have to press the code twice to get it to fully retract- what is the solution to this problems?
GalaxyT25
  • 18 Answers
SOURCE: I was changing the batteries. Now the bolt
Aside from the possibility of the unit "losing its marbles" the only thing I could think would be to reverse the handing by moving the jumper from Pins 1&2 to Pins 2&3 or vice versa... see what effect that has. And if still not working, see what effect it would have to move the jumper back to its original position.
I might also try letting it sit overnight without the batteries in it.
Posted on Feb 07, 2010
koflach79
  • 35 Answers
SOURCE: When I enter my code the bolt only retracts 75%,
Try pulling or pushing the door in while you lock and unlock, sounds like the bolt is binding in the door frame, comon problem with these locks in changing temperatures and humidity.
Posted on Feb 21, 2010
  • 165 Answers
SOURCE: Bolt does not extend or retract. Have replaced
Maybe the connecting wire tape has come loose or gotten damaged.
Posted on Mar 02, 2010
  • 963 Answers
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Mar 05, 2011
  • 963 Answers
SOURCE: HI: Just installed lock and programed
I can't help you directly, but Weiser customer support contacts can be found on this page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Posted on Mar 06, 2011
How do I change the code on a Kwikset key pad
Here you go....
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
Aug 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Just want to change 4 digit code to new one
Do this, with the door open:
Remove cover from assembly by sliding cover up and off. You will then see the program button.
A programmed code can be from four (4) to eight (8) digits long.
Up to 2 user codes can be entered.
Excess delay in the programming steps once started will cause unit to beep twice and will require you to restart from step (a).
Programming the first User Code:
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
Programming the second User Code:
a. Press the program button on the interior unit twice.
After programming in just one new code, the existing old code may still work. I suggest that if this is the case, that you program in two codes to make sure that the old one is over-written. You may try programming in the same new code both times if you don't want to have two codes.
Here is a link to the installation and programming instructions that I excerpted the reprogramming instructions from:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For further assistance or warranty information: call 1-800-677-5625 USA & CANADA
or visit, www.kwikset.com
Jul 26, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Change combination, lost book
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
Here is a link to the complete instructions:
Jul 25, 2011 | Weiser Lock Powerbolt 1000 Lock
I need to reset the code
How do I change the access code (and delete my old code) on my Powerbolt 1000?
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
The lock is installed need to know how to program
First make sure you have the door handing set properly. Retract the bolt manually if extended. Now press the lock button... If the unit extends the bolt, then you're good. If not, switch the jumper position on the control board. If it's covering pins 1&2, move it to cover 2&3 or vice versa.
To program code #1..
Push the program button on the control board once. Enter your 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep. If it doesn't beep, you were too slow. Try again.
To program code #2, press the program button on the control board TWICE. Enter your 4-8 digit code. Push the lock button to end the entry. As before, the unit will emit a 2-second long beep when a successful entry is made.
Test your codes with the door open just to be sure.
Dec 16, 2009 | Weiser Lock Powerbolt 1000 Lock
Lens will not retract
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
48 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
