Super general type sgw-1325
1th step is working but the 2nd step is not working .for this step should the water goes out and the (E) error is comming. please tell me the answer in my e-mail r_ele_machin@libyansteel.com
Maanita
  • 1142 Answers
SOURCE: OUTLOOK EXPRESS
u need to reconfigure your outlook mail account as the incoming and out going server names are causing a problem.if possible plz specify me with the isp name from wich u have subscribed a connection
also u can contact ur internet sc provider for the same..they can help u to reconfigure the account....
Posted on Mar 28, 2008
  • 42 Answers
SOURCE: error code 9-343
all 9-xxx codes are xerographic problems,such as toner,drum,developer or auto density.install or replace one or the other.
Posted on Jun 30, 2008
MNTECH
  • 1543 Answers
SOURCE: hotpoint washer machine repair
If you mean the washer goes up to the rinse cycle and then just sits there, check cold water inlet screen where hose attaches to washer for blockage. #2 could be a bad water valve.
Service outside the US ? Try geappliance.com? or call US 800 #
GE answer center 800-626-2000 ?
Do an "Ask Me" if you have future questions and more details on your washers symptoms.
Posted on Aug 31, 2008
  • 7 Answers
SOURCE: pioneer super tuner 3
first thing you do is switch power on make sure its on then turn the radio off completely hold the function buttom down few seconds clock menu will apear may not right away but you will probly have to scroll through alot diffrent potions like beep on or off you can see when it turns on
Posted on Sep 30, 2008
Cogz
  • 1326 Answers
SOURCE: How to solve the system error E007
That code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
Posted on Oct 08, 2008
My Magnavox DVD reads disc error
QUICK ANSWER
A disc error may be due to having the wrong type of DVD in the player, having a dirty disc in the player or the disc having scratches or cracks. When it comes to the type of disc, it must be compatible with the DVD player for it to work.
FULL ANSWER
When this error occurs, pull the disc out of the player and look at the underside for smudges and fingerprints. If these are present, using a soft cloth to gently remove them generally solves the problem. Cracks and scratches generally require replacing the disc because they prevent it from working.
or try this link..if a popup comes up on the link just close it down.
Step by Step Guide to DVD CD or Game Disc Repair The DIY Video Editor
Dec 17, 2016 | Magnavox Televison & Video
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
a. Check for Kinks.
b. Check for Clogs.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
2002 cavalier slams hitting in 2nd and 3rd gears. Replaced tranny x2 and same issue. Suspect computer issue. Any advice. Have only sm. Computer machine and it shoots u 2000 code .help please. Out lots of...
Sounds to me that you have lack of communication between the PCM and tcm. Generally any U codes are loss of communication on the vehicle LAN (Local Area Network) when this happens, the TCM
(Transmission Control Module) generally goes into limp mode which raises line pressure to max and creates hash shifting. Now the only question is, does the transmission feel like it's trying to pull out in 2nd? When a transmission goes into limp mode, it defaults to second or sometimes 3rd gear. If this is your problem, then you need to find the LAN wire(s) that are down. First step is getting wiring diagrams of the high speed and low speed LAN. Then you need a diagram which shows a map of the direction of travel of the LAN. Then you unplug module by module and back probe and try to see when and if different modules knock out as unplugged This is not a easy feat. This type of diagnostics is generally performed by highly skilled techs.
Jul 08, 2014 | Cars & Trucks
Super general washing machine (SGW 5800) front loader wont stop
Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
Apr 29, 2014 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Laptop runs super slow and I just bought it 3 days ago
STEP 1: Make Computer Faster by Upgrading RAM
Step 2: Make Computer Faster by Removing Computer Viruses, malwares
Step 3: Make Computer Faster by fixing registry errors
(Use PC Fresher)
Step 4: Make Computer Faster by Minimizing Startup Programs
Go to Run.
Type msconfig and press Enter.
The General tab helps diagnose if the problems encountered are with drivers, services, or startup items by unchecking the appropriate boxes and restarting. The Startup tab allows you to individual disable or re-enable startup items.
Oct 08, 2013 | Computers & Internet
How to replace the self igniter on the super flue gas water heater
1) Copy following link for general steps how to take apart combustion parts:
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Copy following link for troubleshoot-igniter pdfs:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
3) Newest gas water heaters require replacing whole combustion assembly.
Older models can be taken apart and igniter replaced separately.
4) Unfortunately Rheem does not post service manuals, or show basic service steps in their product manuals. Parts vary by model number
Feb 13, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Super genral washing machine sgw 615 belt detail
Could you please describe the problem you are having?
Oct 17, 2012 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
