Question about Curtis LCD3235A 32-inch 720p LCD TV Refurbished
Won't scan all channels - Curtis LCD3235A 32-inch 720p LCD TV Refurbished
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
No Database - won't pick up channels when doing the Auto Scan
Mine did that and I had to tighten the connection better from the wall cable into the input.
Feb 16, 2013 | Pegasus St09-b 9-inch Digital Tv Atsc...
Tv won't stop scanning
If the TV is scanning continuously, it may not be able to find any channels with a strong enough signal to select. You may need a better antenna connection
Dec 22, 2012 | Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
AOC LCD27H060 won't find channels
Check your antenna cable connection. Check the center wire of the connector to ensure it is not bent.
Apr 29, 2012 | AOC LC27H060 27 in LCD TV
Tvs get reception from an antena. New LG tv won't acknowledge a dtv channel (kxtv sacramento) when scanned or manually added. Two other digital tvs utilizing the same antena scanned and added the...
The tuner on the LG TV may be right on "the hairy edge" of being able to receive that signal. Therefore the processor won't acknowledge and display it. You may want to try the LG on one of the other antenna feeds were the TVs DO display that channel. You might want to try the LG with no other sets hooked up. You may have a problem with any of the following. - staple through a wire - cracked lead-in wire or damaged coax - problem with a distribution amp/splitter.
Sep 12, 2011 | LG 42 42PT350 42 Plasma TV
Cable won't work after channel 14. Screen just goes to static
You need to make the selection for cable reception in the menu instead of broadcast or air. And when you do then do an auto scan to capture all your cable channels.
May 29, 2011 | Televison & Video
Not enough channels
The history of broadcasting is one of adding more and more channels. The older the VCR, the less cable channels it will get.
Jan 01, 2008 | Toshiba W522 VHS VCR
Curtis LCD3235A 32-inch 720p LCD TV Refurbished Logo
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
