Question about NRS Tool Aid Comprehensive Fuel Injection Pressure Test Kit
Fuel Injection How many Fuel Injectors are on a 1992 Mitsubishi Diamante 3.0L SOHC?
  • 55 Answers
Should be 6
Posted on Apr 24, 2009
I am trying to find the location for my crankshaft position sensor on my 1999 Mitsubishi Diamante
Your 1999 Mitsubishi Diamante is a 3.5L MFI SOHC 6cyl engine.
MFI = multi-port fuel injection
SOHC = single overhead camshaft
This answer covers Mitsubishi Diamante1.8L, 2.4L, 3.0L (SOHC and DOHC), 3.5L, and 1997-2000 1.5L Engines.
2.4L engine shown, others similar.
Fig.1 - CKP position and its two mounting bolts
In Fig. 1, the two arrows point to the CKP (crankshaft position sensor) mounting bolts to remove. 2.4L engine shown.
Fig.2 - CKP reluctor removal
Remove the sensor and slide the reluctor wheel off of the crankshaft-2.4L engine shown.
1. Disconnect the negative battery cable.
2. Remove the timing belt.
3. Unplug the sensor connector.
4. Unfasten the two retaining bolts, then remove the CKP sensor from the vehicle.
5. Installation is the reverse of the removal procedure.
Reference: Autozone online repair guide: Mitsubishi Galant/Mirage/Diamante 1990-2000, at
www.autozone.com
Fig.3 - photo - new 99Diamante CKP, a Wells part #SU4313
Jul 31, 2016 | 1999 Mitsubishi Diamante
Code 41 trouble tree
code 41 fuel injector failure
Sep 08, 2012 | 1992 Mitsubishi Diamante
Where is the fuel switch on a '02 Mitsubishi diamante
all later motors are under the bonnet as far as i know ,only the first of the fuel injection cars from the early 80s were hidden in the door pilar or the boot like the old XJ jags or ford granadas ,look for a inch square red rubber topped thing under the bonnet
Aug 16, 2012 | 2002 Mitsubishi Diamante
Gentlepersons... have 1992SL1 engine died... gong to replace it ,,, but all involved want to know engine type dual cam? vs ? ... can you tell me how to determine whats in the car now.. vin# nails it...
That is pretty easy. If your Saturn is an SL1 it is single cam if it is an SL2 it is dual cam. That is the only difference between an SL1 and an SL2 - Saturn didn't even bother to put a tag or emblem anywhere on the body to differentiate between the the two models. The 8th digit in the VIN will confirm this for you. If the 8th digit is "7" it is a Dual Overhead Cam (DOHC) engine. If the 8th digit is a "9" then it is a Single Overhead Cam (SOHC) engine. When you have seen both engines, it is pretty obvious by simply looking at them. The DOHC cam cover is much wider and has 2 "humps" with spark plugs and wires going down the center between the humps. The SOHC cam cover is narrow and the plugs and wires go down one side.
Also in the 1992 model year, the DOHC engine was equipped with Multiport Fuel Injection. (MFI) The fuel injectors (4 of them) were located in the top of the intake manifold. The SOHC engine had Throttle Body Injection (TBI) The two injectors were located in the throttle body.
I don't have any pictures of the cam covers, but I have pictures of the cam cover gaskets (AKA Valve Cover Gaskets) you can very easilly see the difference.
Apr 28, 2011 | 1992 Saturn SL1
How do i remove the fuel filter as to replace it? (1990 mitsubishi diamante)
Mitsubishi did not make the Diamante in 1990, it came out in 1992, and
on the first gen diamante it's located in front of the passanger side firewall closer to the middle close to the bottom
Mar 09, 2011 | Mitsubishi Diamante Cars & Trucks
Crankshaft position sensor
where it the crank potision sensor on a 92 mitsubishi diamante
Sep 15, 2009 | 1998 Mitsubishi Diamante
Car Hesitation
Check IAC motor - Idle Air Control - and replace.
Apr 24, 2009 | 1992 Mitsubishi Diamante
Air Conditioner
have it serviced by a shop probalby needs it recharged
Apr 24, 2009 | NRS Tool Aid Comprehensive Fuel Injection...
Car Shaking
different things are happening here. get wheels balanced, and motor checked.
Horn
check the fuze
Mar 11, 2009 | 2003 Mitsubishi Diamante
NRS Tool Aid  Comprehensive Fuel Injection Pressure Test Kit Logo
49 people viewed this question
Top NRS Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a NRS Measuring Tool and Sensor Expert? Answer questions, earn points and help others
