I need driver for monitor LG w2241s - Computers & Internet
Not able to set the required resolution (1920 x 1080) for my new LG E2240S monitor. Computer is Advent T9002 on Windows XP
Advent T9002 is using a Sis Ultra256 video card that can't offer you such a big resolution. Your monitor is ok.
You can try to install a more performant graphics card.
May 03, 2011 | Computers & Internet
I have a monitor,model Flatron w2241s-bf,I haven`t used it for 2 weeks,and after that,when I plugged it in,it did`n work,the blue led blinks once for about 1 sec and after that it`s ``dead`` .What`s the...
Components assembled in China are rated for 1000 Hrs. and 85C. Using a Fluke 16 or other Capacitor tester; you will find that the high voltage side of the power inverter has blown Caps and this also takes out the Switch Transistors. You can get these passive components at Mouser.com. Be very careful when soldering these Transistors in. This will solve your problem. I also drill several additional holes in the heat shield and back cover to help dissipate heat from the inverter board. If you are not technically savy in component testing I would recommend purchasing a different model /monitor.
Sep 24, 2010 | LG Computers & Internet
I need a driver for the LG Flatron L1919S LCD Monitor
for what purpose you want the driver for the monitor? generally there are no need to install the monitor driver.
Apr 01, 2010 | LG Flatron L1919S LCD Monitor
Hi, i have a lg monitor studioworks 700s 17". i lost my moniter driver. so i want to download my monitor driver. plz solve my problem. which site is that where i download my monitor driver free. thank you.
connect internet then right click on my computer then click on properties then click on device maneger then right click on monitor then click on properties then select drivers and click on update driver it will automatically install the driver by searching web
Mar 16, 2010 | LG Studioworks 700S 17" CRT Monitor
LG MONITOR 15'' DRIVERS FOR LINUX RHEL FOR LINUX RHEL AS 4 UPDAT
You do not need driver for the monitors otherwise I will be real busy downloading the drivers for 2-300 monitors I repair every year, you do need driver for the video card in your PC. The LCD monitor needs to be fed with 60Hz refesh rate set by your PC and the native resolution it needs.
Jan 05, 2010 | LG L1915S 19" LCD Monitor
I have a LG 17
you may need to download monitor driver for your lg, or re-install your graphic card driver softwares.
Mar 09, 2009 | LG Computers & Internet
I am unable to make resolution 1024 x 768 in lg model 500G
If the monitor is somewhat old and the monitor hardware doesn't support 1024x768 resolution, installing a new driver won't help. You will have to switch to a better monitor.
Dec 21, 2008 | LG Studioworks 563N 15" CRT Monitor
Drivers
go to http://www.Lg.com support drivers you need to check for you model make serial and windows tipe if you can not get it from there you can go to http://www.driversguide.com fill out the registration and go to the LG monitor and look for your model serial and windows system
Dec 14, 2007 | LG Flatron 775FT 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
