Question about Singer Sewing Machines
Rotating Hook won't fully turn-Singer 2210
I have a Singer 2210 sewing machine. I was repairing something that was probably too thick for it to handle and it jammed. Now when I turn the handwheel to feed the bobbin thread through, the "rotating hook" (I think that's what it is called) doesn't turn all the way. Have I broken something or is it possible it's just something that I can adjust myself?
  • 18 Answers
The nylon gear driving the hook has probably broken a tooth. Replacements are available if you search the web.
Make sure you get the matched set of driving gear and driven gear.
Posted on Oct 05, 2009
  • rohmell Oct 06, 2009
    If the gears are not broken, then the setscrews might have loosened up a bit and the gear's timing is off.
    The timing can be reset with info from here:
    http://www.vacsew.com/repair/singer-600-...
My singer confidence quilter 7469 flashes and beeps when i turn it on. there is no repair shop near my town.
Unfortunately, your machine probably needs to be serviced. You can also try contacting Singer support with your problem.
Singer Confidence 7469 Instruction Manual Performance Checklist
https://www.ifixit.com/Answers/View/142928/Why+does+the+electronic+beeper+beep+and+the+sewing+machine+won%27t+sew
Sep 24, 2017 | Singer Sewing Machines
The rotating hook does not recuperate the tread of the bobbin
Probably needs re-timing. This should be done by an experienced mechanic.
In short, your needle is not in sync with the hook as it comes around to pick up the thread.
Apr 18, 2016 | Singer 6423 Sewing Machine
The hook casing that holds the bobbin in my Singer Inspiration 4205 will not rotate when I sew. Therefor the top thread can not pick up the bobbin thread.
there could be something wrong with the hook and hook race, it needs to be checked to see it the parts are damaged or need a adjustment
Mar 07, 2015 | Singer Inspiration 4205 Mechanical Sewing...
How do I fix my Singer 15- 91
Make sure the machine is oiled properly and motor not burned
Apr 30, 2013 | Sewing Machines
The hook on my singer 758 isn't moving.
Take it in for repair. It's probably broken some plastic part inside.
Oct 06, 2012 | SINGER 7470 Sewing Machine
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
How to time my machine
only a sewing machine repair shop has the tools & repair manual to retime a sewing machine
Feb 02, 2012 | Singer Featherweight 132Q Mechanical...
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
I need a circuit board for a Singer 2210 sewing machine
Replacement boards for the 2210 have not been available from Singer since 1998, your best bet is to check eBay for a used or parts machine.
Sep 18, 2009 | Sewing Machines
Raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
Dec 25, 2008 | Singer 6423 Sewing Machine
Sewing Machines Logo
523 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
