Trying to use ant1400 antenna with our seiki led tv se322fs and no luck. Followed user manual can not get dtv signal.
SOURCE: When in Antenna mode (DTV from the Aerial) some channels do not tune in....
I found I needed at least 80 percent.
Posted on Apr 30, 2008
kaytheist
  • 22 Answers
SOURCE: No signal converter box.
Why is this in the computer section?
Anyway, don't exchange the box just yet! First, can you access the converter's menu? Because mine automatically comes up with the "no signal, call customer service" message, but I can access the menu fine -- so the hook-up is not the problem. If you can access the menu, let it autosearch for you, because mine can't be used until I do this. If you get the "weak antenna signal message", refer to the user manual to find out how to check your antenna signal strength; if it's in the weak range, you have to buy a better antenna, most likely from the official source: http://www.accessHD.tv
You can always exchange the box and repeat the process. Getting the "no signal" message is a good indicator that you've hooked everything up right, especially if it's accompanied by a customer service number. You can email me at kalalkb@gmail.com and I'll try to help you troubleshoot the problem if you like. I'm up all night.
Posted on Jun 26, 2008
  • 14 Answers
SOURCE: cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
Posted on Jul 13, 2008
SOURCE: Dynex TV Model DX-LCD32-09 Does Not Pick Up DTV Signals
Yeah I have the same model and there's no built in antenna. You have to use an external. I used to work for the geek squad in a Best Buy store and I can tell you from experience that that salesman may or may not have actually known that there's no antenna built in. It's not uncommon for them to tell small lies like that to get you more interested in the product. I witnessed it a million times before I finally quit because they wanted me to be the same way.
Posted on Feb 28, 2009
  • 520 Answers
SOURCE: DTV1300A Sansui is not dtv ready, Am I doing something wrong?
To put your digital channels into the memory of the DTV1300 or 1900 press the MENU/ENTER button. Go to CH SETUP. Press the VOL + button. Go to TV CABLE. Use VOL+ button to set to TV for antenna or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL+ button. Wait for the search screen to go away after the analog and digital searches finish on their own. Check ALL your channels with the CH up button. I hope this helps you.
Posted on Mar 19, 2009
SEIKI SE322FS LED TV POWER WONT TURN ON LIGHT ON
Could be an open internal fuse or power supply failure
Jun 01, 2017 | Seiki Televison & Video
My tv was on 1 minute and then the picture went out then the sound what could be a problem
Customer Reviews: Seiki 32" Class LCD 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/14978588
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
Customer Reviews: Seiki 32" Class LED 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/19717659
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
SEIKI TV SETUP - YouTube
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
25385173 My 32" seiki TV has no picture but sound
Dec 29, 2015 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Our seiki 20" led tv has a problem with some of the channel are rolling while most are ok we have 3 channel that are doing this. we are connect to a air antenna
I suggest you check the signal strength of the stations in question. It might be that the TV has selected them from a transmitter that is weaker than the main one. If this is the case you might need to do a manual tune on those stations to find the best signal. The TV should have a built in signal strength indicator so you don't need any special equipment. If you do a test of one of the good channels you will see how strong the signal should be.
Mar 02, 2015 | SEIKI Digital SE20HS02 20-Inch 720p 60Hz...
I have sound but no picture on my 32 in Seiki T.V. Model no. SE322FS What is my problem?
turn on the tv. press menu? can you see a menu? if not. your tv requires service.
can you see a menu? might be a connection issue. if you can see a menu respond
Feb 18, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
HI can u Please give me the tv code for my seiki 32in model number se32hy02uk. thanks
what kind of code are you referring to? Not sure I do understand what you want to do with the code.
Feb 16, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
Cant get dtv highlighted in menue on tv
Your TV must receive a digital signal in order for the DTV option to be available. Since you are not seeing all of the channels when you auto scan then it can be assumed that the signal cable connected to your set is not providing the digital signal. Make sure you are scanning for the proper source of your signal ( Cable TV, Broadcast TV)
Nov 29, 2014 | Seiki 32" LED TV - SE321FB
Why am I getting a no signal alert? Top right corner says MDMI.
Check its input settings. Refer its user manual for details. Select the input as TV; and connect the external antenna; and check whether the TV receives any on-air signals. If not, its tuner is faulty. Contact any service technician to replace this part.
25278449-dozcisxt5ozbaqxvby5u5h52-4-0.jpg Electro help
Nov 11, 2014 | SEIKI Digital Seiki SE22FE01 22" 1080p...
Seiki se322fs won't turn on
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 16, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
SEIKI SE322FS LED TV won't turn on, but power light is on
From your description there are blown electrolytic capacitors on the power supply board,a visual inspection will show bulged burst or leaky caps.I am assuming there is no sound or pic and no visible light from the screen.I must assume you have no prior electrical service knowledge and warn of possible high voltages being present on the primary side of the power supply at the 400volt filter cap
also be sure to unplug the set before removing the back pannel
keep safe
Len...
Oct 13, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
