Question about John Deere 50 60 70 520 620 720 Power Steering Plate
John Deere 50 steering oil blows out of filler cap
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
SOURCE: John Deere Gator XUV 2008 oil in gas
I know exactly the problem. I work for a John Deere dealership and have seen this problem before. It is called short-tripping. When a machine is first started, gas does leak into the cylinder and crankcase past the rings--normal--simulates leaving the choke on too long with a carburetor engine.. As the engine temperature rises, the gas in the oil is burned off and there really isn't a problem. When you take short trips or do not let the engine run to get it up to temperature, the gas in the crankcase does not get burned off and will accumulate over time. Make sure the machine is getting up to operating temperature and this could take up to 20 minutes if the ambient air temp is low. Feel free to e-mail at ericf@greensouth.com with further questions
Posted on Dec 16, 2009
wireguy212
  • 1627 Answers
SOURCE: What would cause my John Deere Sabre 25hp 54"cut
Your tractor has a simple worm gear turning another worm gear system.Either the one of the spindles in the front wheels is sticking or the worm gear is not meshing or you need to replace the worm gear on the steering shaft it's self.Also,if the tie rods are not set right then the wheels may turn hard,set the tie rods so that they have 1 to 1 and 3/4 inches of tow in in the front wheels.
Posted on Sep 16, 2010
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
John Deere LT 155, why are small amounts of oil dripping into the carburetor air intake thru he oil breather hose connected to that air intake chamber
the breather hose is the means of allowing the compression by pass gasses to not build up pressure in the sump and it exits into the air inlet system near the air cleaner
for oil to be dripping there indicates
1--excessive oil in the sump
2-- worn rings allowing excessive blow by and boiling the sump oil
3-- incorrect oil used in the sump ( too thin) try a 30w -50 grade
Dec 18, 2016 | John Deere Garden
What hydro fluid does a john deere 333d skid steer use
333D uses a variety of oil for the hydraulic system. Primarily 10W-30 Torq-Guard Supreme or 10W-30 Plus 50 II
EXCEPT: If your machine was equipped with the cold start package, it will use either Plus 50 II 0W-40 or Hydrau XR (Hydrau XR can be added to Plus 50 II 0W-40 in any ratio, ie. topping off 0W-40 with Hydrau XR is okay)
Dec 08, 2015 | John Deere Garden
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
Crankcase pressure
if under warranty take back to authorized dealer, check threads or attaching method used for filler cap to be in good condition, if good check crankcase vent tube for kink or obstruction.
Sep 01, 2014 | John Deere Garden
Where is the hydraulic oil resivore on a John Deere 420 garden tractor?
Its the transmission itsef, you fill it from under the hood between battery and steering console. Its a little black cap that lifts off tube.
Jun 20, 2011 | John Deere 420,1020,2010,2020,2510,2520...
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
John Deere 50 60 70 520 620 720 Power Steering Plate Logo
26 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
