Driv bel
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Posted on Aug 31, 2009
SOURCE: My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Posted on Sep 24, 2009
SOURCE: i cannot start my Suffolk punch 43s petrol mower,
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Posted on Oct 03, 2009
SOURCE: Qualcast Suffolk Punchbowl will not start, have
it sounds as if the air filter is choking the engine take air filter off and see if the same happens, other than that it could either be plug needs changing
Posted on Oct 17, 2009
Nov 17, 2017 | Garden
Aug 02, 2016 | Garden
Aug 11, 2014 | Garden
Jun 09, 2013 | Garden
May 30, 2011 | Garden
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Jan 10, 2018 | Garden
Aug 30, 2009 | Garden
Aug 22, 2009 | Garden
Jul 27, 2009 | Garden
21 people viewed this question
