Question about Canon i860 InkJet Photo Printer
My printer was working fine yeserday now it wont work.
Now it starts to bring the paper in to print then the paper get crumpled half way and it stops. What should i do?
  • inkypete May 11, 2010
    It's possible you have small small piece of paper jammed in there
    President:
  • 1,335 Answers
It sounds like you have a fragment of paper or something else jamming the paper path. Try dislogding it by running a tranparency sheet (or 40 weight heavy paper) through the paperpath.
Posted on Apr 26, 2009
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Every time i try to print the paper starts to roll down ,but crumples on one side then stops
Hello, 90% of the cases there is a foren object in the paper path. Try to locate the object and remove it with a fishing calmp.
Sep 30, 2012 | Canon Ink Cartridge for Pixma MP252
My HP Officejet 6500 Wireless just started printing a blank page and bringing up the error message "Paper Mismatch' - been using this for over a year with no probloems
1. Unplug the power cord from the back of the printer. 2. Press and hold the # key and the number 6 and plug the printer back in all at the same time. 3. Release the keys once the printer is already turned on.
If the printer takes the paper but only crumples it. Do the Reset for the 2nd time.
Feb 03, 2011 | HP Officejet 6500 Wireless All-in-One...
I C309 printer not pulling paper correctly every time and crumple
HEY YO! THIS IS A CAR(YOU KNOW AUTOMOBILE)FORUM,NOT COMPUTERS FOR DUMMIES!!!!!!DUH!!!!
Dec 18, 2009 | 1996 Chevrolet Cavalier
Printing pictures photo paper gets jammed half way?
There are many reasons why your photo paper gets jammed, but here the most common ones:
- The photo paper is crumpled, or the edges are fold. Be sure that the paper is completely straightened out before putting it in the feeder.
- Your tray lock is larger than your paper. It is recommended that you keep your tray holder lock the size of your paper. The best way is still to keep a .5cm allowance.
- There is something blocking the feeder which causes the paper to go out of track. Are you sure there isn't a crumpled paper or torn paper left with the feeder?
HTH!
Dec 12, 2009 | HP LaserJet 5200 Printer
Hi my name is Lecette. I am having some trouble printing on my lexmark x5470 printer. When I print the paper slides in 3 inches and starts to crumble up and jams. Is there any way you can assist me with...
if the paper is crumpling up then something is stopping the paper from moving check the paper path for obstructions. if your first set of feed roller are moving and the second set is not then this will happen also
Dec 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
HP PSC1410 All in one
crumpled papers are due to something stuck inside, or the rollers are dirty, causing a misfeed
new print drivers are sometimes needed after fixya this sort of issue. get em here
Mar 23, 2008 | Office Equipment & Supplies
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
Canon i860 InkJet Photo Printer Logo
97 people viewed this question
old marine
old marine
