Question about Clothing Accessories
Cannon oakley oven not igniting - Clothing Accessories
My cannon duo cooker was working one day then next day the clock doesn't work, the ignition wont work theres no gas coming through to lite oven manually whats the problem the rings work perfectly
Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
Mar 26, 2016 | Cannon Kitchen Ranges
How do i change the bulb on a cannon oakley gas cooker
Turn lamp cover anticlockwise .fitted at rear of oven
Mar 02, 2015 | Cannon Kitchen Ranges
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
Cannon oakley oven not igniting, but ignite clicking
short on HV wire or electrode. >> remove HV wire from electrode and check spark from end of wire to frame, if its ok, then electrode porcelain might be cracked.
Oct 13, 2013 | Ovens
Ignition not turning off once oven lit
It is normal for the ignitor to stay lit while the burner is going...There is nothing wrong there...
heatman101
Apr 07, 2010 | Ovens
Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Nov 24, 2009 | Ovens
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
MY CANNON CAMBERLEY DOUBLE OVEN HAS HAD A REPLACEMENT FSD BUT IS STILL NOT WORKING PROPERLY.
MY CANNON CAMBERLEY main oven is not working at all. No Gas, no ignition, hobs are okay, clock is blank.
Nov 04, 2008 | Kitchen Ranges
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Clothing Accessories Logo
27 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
