Question about Dryers
Hoover hd vision tumble dryer instructions
Cant get bottom slot to fit back in
yalmer
  • 552 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
dragonsthatk
  • 547 Answers
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on May 02, 2009
SOURCE: I have a Hoover vision hd b energy condensor dryer
My engineer is coming out, didnt realise i had to pay for this assistance,it made out on the ad that someone was able to help you by giving advice,it didnt state you had to pay, for i thought forget it.
Posted on Aug 27, 2009
SOURCE: Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Posted on Jun 29, 2010
How do I replace the door switch
Go to espare.com and watch the vidios about that
Dec 04, 2015 | Hoover Vision HD VHC691B White Electric...
How do i get access to the motor on a hoover vhv781c tumble dryer as i need to replace the capacitor
Hoover vision hd tumble dryer VHC680F 16/10/2012 ...
? 0:19
https://www.youtube.com/watch?v=WCiQ9qc2TWk
Oct 16, 2012 - Uploaded by Ben Smith
Ben did you manage to change the capacitor? I got the same problem but I cant actually get close enough to the capacitor to replace it!.
Nov 26, 2015 | Hoover Vacuums
I am replacing the door of my tumble dryer and I need to know haw to assemble.
photo graph it with ure phone then put it back togather in reverse order
Feb 06, 2015 | Hoover Vision HD VHC691B White Electric...
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
How to work the hoover vision hd vhv 381 tumble dryer?
This may not be exactly what you want, but is useful information for anyone wanting to work on their hoover dryer, vision hd vhc 381 dryer.
Fixed: dryer not heating up (Hoover vision hd 381)
Just fixed a hoover vision hd 381 tumble dryer. Thanks to the help on this site and others. Thought I would share my experience here. Problem was tumbledryer not getting hot. Traced it fairly quickly to a blown heating element. Took the back heater cover off (bulging silver panel), unscrewed heater, peered inside and it was somewhat charred (tested the thermostats which were fine). Dryer works now.
The really tricky thing was unplugging the heating element to replace it. The plugs are located inside the main housing.
However, the advice found on much of the internet to how to do this is incorrect. In particular the advice to remove the drum is not correct.
The way you access the plugs is by pulling the main heating wire through the hole in the unit, and feeding the plugs through one by one.
Then you can simply unplug the old one, plug in the new one.
Two things are necessary for this:
i) Remove the rubber collar keeping the main wire secure in the hole into the main unit.
ii) Pushing the plastic grommet through the small hole in the main unit. This grommet immobilises the main wire - you won't feed it through without it being released. You'll see quickly what this looks like on the replacement heater you should already have. The white plastic grommet protrudes a little out of the back of the unit close to where the heating wire enters the unit. Pinch it with a pair of pliers and push it back into the unit. The wire will then be free to pull through, and one plug at a time will fit through till you have all four. Then just pull the plugs off (pushing the new ones on requires quite alot of force).
In fact it is not necessary to strip down the unit at all to do this, apart from one thing: putting the grommet back for the new heater. It needs to be pushed from the inside. This probably isn't strictly necessary (I say probably), but I did it anyway. I suspect the grommet is there so that if the heater hangs free, it doesn't pull the wire up and stress the plugs. But I wanted to put the thing back exactly like I found it.
However, you still don't need to take the drum out to do this. You do however need to take the plastic mounting off that supports the drum. Then you can reach in with your hand and manouver the grommet into place.
So the repair ideally should be firstly to replace the heater in the way described above. Then put the cover back on as you'll need the unit on its back later.
Briefly, instructions for stripping down the unit:
i) Unscrew the 3 top screws located on the back of the unit holding the top of the unit on. Slide the top back and lift it off.
ii) Disconnect the door by undoing the allen key screws. Once these are off, lift the door off.
iii) Unscrew the plastic faceplate from the top (2 screws), to reveal two of 8 screws holding the metal front in place. I wired the plastic faceplate (with control knobs) onto the unit so I could still access these 2 screws, without the faceplate hanging free and risking disconnecting something.
iv) Unscrew the remaining 6 screws (4 near the rubber seal, 2 at the very bottom). Remove the rubber seal carefully.
v) Lift the metal front off, and disconnect the wires (keep track of which goes where!) Place the machine on its back (support it with blocks where the bulging heating element is).
vi) Unscrew the four nuts holding the plastic mounting which supports the drum.
vii) Slide the plastic mounting up by about 10mm and hinge it out from the bottom. This lifts the felt seal off the drum. The machine needs to be on its back so the drum which is now only held on to the back plate doesn't stress itself under its own weight. Make sure you know where the wires need to be fed. I took videos and pictures on my phone at each step.
viii) It should now be possible to reach in past the drum and click the grommet back in place.
cheers
Mat
(matskm@gmail.com if anyone wants to ask questions).
Aug 02, 2010 | Hoover Dryers
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Dryers Logo
22 people viewed this question
Top Dryers Experts
