Question about Konica Minolta Minolta 7222 Laser Printer Toner Cartridges
Konica minolta 7222 copier have problem (close right side cover) but cover is closed and i have already replaced door switch and power supply board and main board and cassette board and fixing board.kindly advise Tariq e_tech_pk@hotmail.com
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Oh boy. Here goes. We have a Bizhub C450 copier
Press Utility/Counter
Over at the right side of the display touch "details"
Now press Stop, 0, 0, Stop, 0, 1
This should get you to the service mode screen
Now touch Counters
Now you can touch either upper right corner is Jam
lower right corner is jam history.
For our purposes the Jam tab will be better. You can just list any location that has a number next to it greater than zero. There are 2 screens to look at as there is a 1 and 2 at the left side.
Obviously we are going to want to concentrate on the lines/locations with the biggest numbers. If there is one location for example that has 40 jams on it and the rest are 3 or 4 then that will tell you where the problem location is.
Now another word of caution. We do not know how long it has been since these counters were reset, if they have ever been reset. So once you get all of the locations listed with how many jams there were I would exit the screen to where you first entered the service mode and now touch the reset tab then the jam tab so as to reset the counts. Now as you run the copier we will have a fresh set of jam counts by location in case we need it later.
Good Luck
Posted on Jul 23, 2010
Testimonial: "The Guru is by far the most intelligent, honest, copier genius I have ever met. He will solve your problem from the start! I can't thank him enough!"
resonatom
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
Posted on Mar 09, 2012
I have Konica Minolta B250it does not warmup.the fused unit is cold and the touch screen is not responding just freezing. I have tried trouble re-set changed fuser unit. Changed control panel nothing is...
Fuser Error is not getting reset.
Try to look into the Right Door SWITCH which is located behind the Front Toner Door.
U need to remove front cover and u will find switch back of steel cover.
check the actuation once u close right side door, it might not be on or off by opening and closing right door..
Jul 21, 2017 | Konica Minolta Office Equipment & Supplies
Closed 1st side cover konica minolta bizhub 185
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Dec 09, 2016 | Konica Minolta bizhub Office Equipment &...
How do i reset error code 3922 konica minolta c3350
Check 1st the following : Fusing unit • Fusing temperature sensor/2 (TEM2) • DC power supply (DCPS) • Printer control board (PRCB). If everything ok then RESET thru [Utility]
Dec 12, 2014 | Konica Minolta Office Equipment & Supplies
Minolta di251 co500
Sir/Mam,
First ensure that the right side of the machine is closed there are two latches on the side door inside are either one broken? if not ensure the door is closed. Take a paper clip on the right side of the control panels a small hole touch the switch inside with the paper clip. (From then on only that paper clip can be use to this:):):)) The screen will state abort that OK, then the screen with three little copier comes on to the left on the control screen will be a small blue/purple dot when it shows hit 3. Then when you go to utility/counter screen there will me a maintenance mode touch it. touch TROUBLE RESET let machine do its thing code should go away. if it comes back there is a problem with the switch in front cover you can not see and the fusing unit the hot part and the side door not keeping the switch you can't see closed telling the copier to provide 117VAC wall outlet power to the fuser unit the hot part.
Oct 25, 2013 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
How to check toner supply motor if is working
close right side cover ,i have already replaced door switch and power supply board and main board and cassette control board and fixing unit.kindly advise what can i do ?
Feb 18, 2013 | Konica Minolta Minolta 7222 Laser Printer...
My bizhubb c250 is displaying
open front door then push the IU correctly then close the door and close the side door from your right side...
Nov 14, 2011 | Konica Minolta bizhub C250 All-In-One...
How do I clear error code C3B04
Turn the machine completely off with main power switch inside machine then holding down the Utility/counter turn the machine on and close the door ensure sub power switch is already on that's the one on the side of the op panel wait to see Trouble reset on screen touch should read OK then power off then power on WAIT TEN SECONDs ALWAYS BEFORE powering back up. If the code comes back need a new fusing High Current Board. Some serious bucks:(
Sep 22, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Di 520
Try resetting the copier first, power on - open the front door remove small cover on the right hand side press reset button - close door. The machine should now boot, but if the fault is still present a service call will be required.
May 09, 2008 | Minolta DiALTA Di520 Laser Printer
Konica Minolta Minolta 7222 Laser Printer Toner Cartridges Logo
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
