Question about Sony CDX-L350 CD Player
Sony CDX-L350 radio has failed, no sound of any kind. However, the CD player works fine. I have tried the reset button but no change. Tony
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Posted on Jul 11, 2009
SOURCE: Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
i have the same problem, it was a factory fit and the garage checked it and all the connections were ok, it appears to be a fault with the receiver.the radio is just 3 years old.
Posted on Mar 25, 2010
SOURCE: Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Posted on May 10, 2010
SOURCE: sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Posted on Aug 08, 2010
SOURCE: Sony CDX-4000R not receiving radio signal. CD
I just need to know what wire goes on what pin on the back of the set pleaseeeeeeeeeeee
Posted on Mar 22, 2011
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
My Sony CDX-L350 CD Player's volume buttons dont react no matter how hard i press them, and i cant adjust the volume
Hi Kenny,
There is a manual reset that is used as a catch all remedy to handle symptoms of an unspecified origin.
It's located on the front of the unit, behind the front panel, directly behind the "ATT" button. Get a paper clip and press it.
Best regards
Aug 15, 2010 | Sony CDX-L350 CD Player
Sony Xplod CDX-M610 has blank faceplate
It sound like it has jammed in the mechanism, try pressing the reset button on the back plate, if this dont work you may need to remove the radio or fuse otherwise it may flatten your battery.
Dan.
Nov 24, 2009 | Sony CDX-M610 CD Player
Hi , I have a Sony car Stereo CD player Model #CDX-L350
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C385125
Frank, try this link for wiring connections...looks like there are 2 different pin outs available here. Hope this helps.
Aug 23, 2009 | Sony Car Audio & Video
CD's keep spitting back out of player which is in caravan
The drive(optical) drives door mechanism has malfunctioned. If the PC CD drive can be replaced that would be the best, but repairing is also not cost-effective...........sodeep
May 12, 2009 | Sony CDX-L400X CD Player
Display doesn't display info....just bright light
Have you tried resetting the unit? Remove faceplate and push the reset button with a ball point pen. If it's a bluetooth model there is a different procedure.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 25, 2017 | Sony CDX-M610 CD Player
CD RESET
Jan 16, 2009 | Sony XPLOD CDX-GT200 CD Player
CDX-CA680- Cd player not working,
You are probably making the same mistake I did. The CD should be inserted BEHIND the front of the radio in the slot provided, press open on the front of the radio and all will be revealed! The CD trays underneath the radio are for storage only! Hope this solves the problem for you.
Jun 24, 2008 | Sony CDX-CA680X CD Player
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Sony CDX-L350 CD Player Logo
55 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
