How can i fix my apple imac if it doesnt turn on?
    Top Expert:
  • 12,223 Answers
See the details.and fix it. God bless you
Check to see that the power cable is properly connected to the computer and the outlet. You should also check to be sure that any power strips are on and working. Try starting your computer from several electrical outlets.
  • 2 Press the "Caps Lock" button on the keyboard and see whether the green light comes on. If the light comes on, but your Mac won't start, the computer might be asleep and may need to have the power management unit (PMU) reset or serviced. Press and hold the power button for 5 seconds to see whether the computer will turn off or wake up.
  • Sponsored Links
  • 3
    Insert the the Mac OS X CD and hold the "C" key while powering on your computer to boot from the disc and not the computer's internal drive. Run Disc Utility from the CD to diagnose and attempt to repair some hardware problems. You can also erase the hard disc and reinstall OS X with this method, although you won't have a chance to back up your data.
  • 4
    Reset the power management unit by disconnecting the power cord from the back of your computer. Wait 2 minutes before reconnecting the cord and turning on your computer. Laptops and older computers have different procedures for resetting the PMU, which you can get from Apple's website (see Resources below).
  • 5
    Drain the logic board's battery on your Mac. Disconnect the battery (for a laptop) and the power adapter, then press the power switch and let the computer sit for about 25 minutes before reconnecting and booting it. This step forces the computer to reset its logic board and all other components that use the backup electrical charge.
  • 6
    Open your computer and remove any RAM upgrades that you've installed. See whether the computer starts up without the extra memory. Incompatible or incorrectly installed memory can make your computer unresponsive.
  • Read more: http://www.ehow.com/how_2091893_troubleshoot-mac-that-wont-start.html#ixzz2hhE0JkWY
    Posted on Oct 14, 2013
    2 Suggested Answers
    MacApplePi
    • 82 Answers
    SOURCE: Apple iMac 17 Model A1058 won't turn on
    Re the light turning on for about 3 secs.
    Does the computer make a 'start up' chime or any other tones?
    If not, this could be for a variety or reasons.
    Firstly you need to verify that the power supply is working. Remove all connections from the computer including the keyboard and mouse. Try to start up again. If the computer still fails to start up, you will need to gain access to the computers internals.
    Lay the computer face down on a soft cloth to protect the screen. Undo the 3 silver screws on the lower edge of the computer. (one at each end and one central. These are captive screws.)
    Lift the rear cover away from the main body of the computer.
    On the Logic Board there are 4 diagnostic LEDs indicated by a yellow arrow on the board. To the left of these LEDs there is a small button. This allows you to power on the computer with the rear cover removed. Connect the power lead. LED1 should be 'ON'. If it is 'OFF' then you need to replace the power supply.
    Turn the computer on by using the internal power button.(LEDs 2&3 should now be 'ON'. If LED2 only comes on momentarilty then replace the power supply).
    Does the computer start up normally after pressing the internal power button?
    - Yes: Press and hold the power button until the computer powers off.
    • Unplug the power cord from the iMac, and reinstall the back cover.
    • Return the computer to the upright position.
    • Plug the computer back in, and press the power button to turn on the computer.
    • Make sure the computer is starting up properly. If the computer will ONLY start up
    from the internal power but will not power on from the power button on the back
    cover, the power button on the back cover may be faulty.
    - No: Reset the SMU.
    • Unplug all cables from the computer, including the power cord.
    • Wait 10 seconds.
    • Plug in the power cord while simultaneously pressing and holding the power button
    on the back of the computer.
    • Let go of the power button.
    • Press the power button once more to start up your iMac G5.
    If the computer starts up normally then shut down and replace the rear cover.
    If you feel uncomfortable about working on the computer, take it to a reputable repairer.
    Hope this helps.
    Posted on Jan 05, 2009
    Imac start up problem
    Hope you can access another computer.
    Search box. Type in how to reset an iMac
    Switch off, hold down command+R keys and turn on. This is a complete reinstall factory settings. You will lose all your saved data. Sorry, hope it solves
    Mar 15, 2014 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
    My imac got start up problem
    Get your mac repair as there is a problem called boot crash.
    Why does my iMac stay on a white screen when started?
    Here's a video Charles East suggested as a solution to your problem from YouTube:
    How To Fix White Screen On Your Mac
    Mar 24, 2013 | Apple 24" iMac Desktop
    Imac 24 inch doesnt have sound
    Go to your system preferences,
    the sound control panel.
    Make sure the internal speakers are selected there and that it is not muted or turned down there.
    Aug 07, 2012 | Apple iMac 24 inch 2.4GHz/ 1x1GB/ 320GB/...
    How do i fix my imac computer if a black console screen doesnt let me boot up the computer
    Hardwares problems maybe, it's better to take it back to Apple , they should be helpful.
    Android 4.0 Tablet PC
    Dec 26, 2011 | Apple iMac G5 Desktop
    Mac desktop stop at apple loading screen how do i fix this
    Try to force quit the Applications
    1. Go to the top right part of the screen and click on the Apple logo.
    2. Click "Force Quit"
    3. Select the Application you are in or all of them and for each click "Force Quit"
    If this doesn't work try to restart your iMac
    1. On the back of your iMac locate the power button in the bottom left.
    2. Hold down the button and then the iMac should turn off.
    3. After a minute or so, try to turn the iMac back on again, it should be operating normally.
    Mar 23, 2011 | Apple eMac Desktop
    My imac 21.5 10.6.6 doesnt starts up it freezes on the white screen w. the apple and the loading bar or circle!
    Try turning on the computer while holding down Command+Option+P+R until you hear the boot tone twice.
    Mar 13, 2011 | Apple 21.5" iMac Desktop
    My imac g5 wont turn on at all! what can i do?
    First, you should make sure you you have power to the iMac. Next if you checked you don't have power the iMac and you do, you could bring it to an Apple Store near you so they can diagnose it. Note, " I pretty sure they could diagnose it." Then if they know what the problem is, you could buy the parts needed from sites that have them and replace the faulty parts. You might be able to find how to replace the parts on www.iFixit.com. If this isn't what you are looking for you should probably clarify your qustion because the question has tons of possibilities. Hopefully this can help!!!!
    Note: The Apple Store people might be able to fix the iMac for a price.
    Mr Fixya533
    Feb 07, 2011 | Apple iMac G5 Desktop
    I turn on my imac and it makes the boot sound but the screen doesnt turn on what should i do?
    Attach an external monitor to the port on the rear of the iMac (requires a mini-VGA to VGA adapter). If the external monitor shows image, then you have a bad inverter or LCD panel, or a disconnected display cable. If the external monitor shows no image, then it is something else, and whatever it is will probably require a logic board replacement, which is not cost-effective in a machine this old (unless you have an unusual source of used parts).
    Oct 25, 2010 | Apple iMac G4 Desktop
    I locked myself out of my imac using leopard when my friend an e dell tec got in for me ithink he upgraded it to snow when in plugged it by accident and turned it back on it camer up telling me tgo restart...
    1.: Find the disc that came with your iMac that says "iMac OS X Install DVD"
    2.: Turn on your iMac
    3.: Insert the disc into the SuperDrive
    4.: Turn off your iMac
    5.: Press down on the "Option" key on your keyboard, and keep it held down
    6.: With your other hand, press the power button on the back of the iMac for 1-2 seconds
    7.: A screen should come up with a picture of a hard drive, and a picture of a DVD
    8.: Let go of the "Option" key
    9.: Using your mouse, click on the arrow under the picture of a DVD
    10.: Follow the on-screen instrustions, which will guide you through the process of re-installing OS X Leopard on your iMac
    Sep 26, 2009 | Apple iMac 24" Desktop
    Computers & Internet Logo
    123 people viewed this question
    David Payne
    David Payne
