Question about QVS NetStar (UPS650A) UPS System
Bypass fault - QVS NetStar (UPS650A) UPS System
2013 peter bilt 587 won't idle longer than five minutes, how do I bypass it?
Maybe it just needs serviced. You have a high dollar engine in there and the PCM/ECM is just trying to save it. Have the codes read.
Jul 18, 2015 | Cars & Trucks
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
2004 niisan infinty g35x code p2135
NISSAN OBDII DTC
P1105 Manifold Absolute Pressure/Barometric Pressure Switch Solenoid Circuit
P1110 Intake Valve Timing Control Circuit (Bank 1)
P1120 Secondary Throttle Position Sensor Circuit
P1125 Tandem Throttle Position Sensor Circuit
P1132 Intake Valve Timing Control Position Sensor (Bank 1)
P1135 Intake Valve Timing Control Circuit (Bank 2)
P1137 Intake Valve Timing Control Position Sensor (Bank 2)
P1140 Intake Valve Timing Control Position Sensor (Bank 1)
P1145 Intake Valve Timing Control Position Sensor (Bank 2)
P1148 Closed Loop Fault Detected (Bank 1)
P1168 Closed Loop Fault Detected (Bank 2)
P1210 Traction Control System Signal Fault
P1220 Fuel Pump Control Module Fault
P1320 Ignition Control Signal Fault
P1335 Crankshaft Position Sensor Circuit
P1336 Crankshaft Position Sensor circuit
P1400 EGR/EVAP Control Solenoid Circuit
P1401 EGR Temperature Sensor Circuit
P1402 EGR System Fault Detected
P1440 EVAP Canister System Leak Detected
P1441 EVAP Vacuum Cut Valve Bypass Valve Circuit
P1443 EVAP Canister Control Vacuum Switch Circuit
P1444 EVAP Canister Purge Volume Control Valve Circuit
P1445 EVAP Purge Volume Control Valve
P1446 EVAP Canister Vent Valve Circuit
P1447 EVAP Canister Purge Flow/Volume Control Valve Circuit
P1448 EVAP Vent Control Valve Circuit
P1490 EVAP Vent Control Valve/Bypass Valve Circuit
P1491 EVAP Vacuum Cut Valve/Bypass Valve Circuit
P1492 EVAP Canister Purge Control Valve/Solenoid Valve
P1605 Transmission Control Module A/T Diagnosis Communication Line Fault
P1705 Throttle Position Switch Circuit
P1706 Park Neutral Position Switch Circuit
P1760 Overrun Clutch Solenoid Valve Circuit
P1900 Cooling Fan Control Circuit
sorry but your code reader is not reading manufacturers codes ,if an american market vehicle then you should be able to read them but if this is a europeon model then how did you manage to get this code??
P0235....Turbo/Super Charger Boost Sensor 'A' Circuit
this is a generic code if its any help
Nov 02, 2010 | 2004 Infiniti G35 Sport Coupe
P 2138 code with service engine soon light on?
Accelerator Pedal Position Error.
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
Clear the code - if it recurs, change the sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | 2006 Nissan Altima
If yellow cartridge is empty, can I configure HP 2550N to print in Black and bypass the fault condition I have...
no. this printer uses a four color black. you are unable to bypass the yellow cartridge.
Sep 24, 2009 | HP LaserJet 2550n Printer
Bypass LED on the ups is on
This an excerpt from the UPS's manual:
The Bypass LED illuminates indicating that the UPS is in bypass mode. Utility power is sent directly to connected equipment during bypass mode operation. Bypass mode operation is the result of an internal UPS fault, an overload condition, or a user initiated command through an accessory. Battery operation is not available when the UPS is in bypass mode.
Jul 19, 2009 | APC Smart-UPS 1000VA UPS System
Th imobilzier light stays on we have been told this is a transponder fault can i bypass this .
You paid for it to do what it's doing, don't bypass it, have it looked into.by the dealer. or at least call it in ?
Jul 14, 2009 | Nissan Minivan Cars & Trucks
99 Saturn SC1 ''Service engine soon'' light is on.
Did you get the code that triggered the SEL? If you know that, it will be easier to diagnose your problem. You can do it without a tool on the old saturns. Just need a paperclip. :
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the connector. Terminal B is directly adjacent and to the left of Terminal A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the SES light by flashing the light with short and long pauses to distinguish digits of one code from digits of another. The short pause is used between digits of the same code, long pauses are between codes. Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause, flash-flash, long pause, then repeat 2 times. If Code 12 is not displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2 light will begin flashing transaxle codes of flags.
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
Feb 24, 2009 | 1993 Saturn SC1
QVS NetStar (UPS650A) UPS System Logo
22 people viewed this question
Top QVS Computers & Internet Experts
David Payne
David Payne
Are you a QVS Computer and Internet Expert? Answer questions, earn points and help others
