Question about Burris - Fullfield II Scope
I need the rubber ring on the eye piece of a burris fullfield II , OD is 1.5 inches MOL
  • 243 Answers
Call the manufacturer. They can help you.
Posted on Apr 20, 2014
What is the empirical formula of a compound that contains 50.0% carbon, 6.7% hydrogen, and 43.3% oxygen by mass?
CH2O
n(C) = 40.0 g / 12.01 g/mol = 3.33 mol
n(H) = 6.7 g / 1.01 g/mol = 6.63 mol
n(O) = 53.3 g / 16.00 g/mol = 3.33 mol
C: 3.33 / 3.33 = 1
H: 6.63 / 3.33 = 2
O: 3.33 / 3.33 = 1
Mar 24, 2015 | chemistry.com Computers & Internet
CANNOT FIND 1/8 INCH ID, 3/16 INCH OD, 250 PSI MINI AIR COMPRESSOR HOSE
You can find this kind of stuff at hydraulic repair and fabrication shops, check the phone book.
Jun 22, 2012 | Cars & Trucks
Where can I get replacement caps for the elevation adjustments.
the only way to find cheap caps it try a fuw gun shops to see it they have any old scope that dont work and buy the caps that will fit your scope most gun shops keep old broken scopes just for that?
Nov 27, 2010 | Burris 3-9x50mm Fullfield II Rifle Scope...
I have a DS114 Electronic Digital Meade. I only
1 1/4 inch OD is a standard size for eyepieces. You should be able to buy eyepieces in other focal lengths at any shop that sells telescopes, or online. I found hundreds of them with a quick search on Amazon, some made by Meade.
Nov 04, 2010 | Meade DS-114EC (325 x 60mm) Telescope
How to use that front yard adjustment on Burris fullfield II
That "front yard adjustment" is called the "Parallax adjustment ring". In order to get the sharpest image, and to reduce slight movement of the view when your head is out of alignment with the centerbore of the scope, set the yardage indicator at the distance you are shooting. You can fine tune the sharpness of the image by turning the ring slightly in either direction once you have made the initial setting. Most distance indicators are off slightly from the actual best setting.
Jan 17, 2010 | Optics
I bought a used scope with no manual. On the front of the scope it turns like the back but it has ranges on it do I need to know what range I am shooting for the rifle to be accurite
Take the bolt out of the rifle so you can sight down the barrel to the target. Get the target bullseye in the center of the barrel. Now look through the scope to see where it is. Adjust the windage and elevation screws to get the cross hairs on the bullseye. Look through the barrel several times to make sure the gun did not move off the target during the adjustments. A concrete bench with sandbags is best to use for this.
Dec 05, 2009 | Burris Fullfield II Riflescope
Soon as it gets cold out it seems to want to get blurry
If your scope is fogging it has lost the nitrigon in it and you will have to send it back to the factory to be refilled and resealed. I would send it back to burris.
Nov 13, 2009 | Burris Fullfield II Riflescope
The rubbers on the eye pieces are deteriorated are they available anywhere
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Sep 22, 2009 | Tasco Off Shore OS21 (7x50MM) Binocular
Replacement parts for Tasco binoculars
Sep 18, 2009 | Tasco Wide Angle and Rubber 2023 (10x50MM)...
Burris - Fullfield II Scope Logo
81 people viewed this question
Top Burris Optics Experts
Tom Chichester
james laughton
james laughton
RichardL
RichardL
Are you a Burris Optic Expert? Answer questions, earn points and help others
