Question about Cuisinart SS-700 5-Cup Coffee Maker
When brewing it makes a loud noise - Cuisinart SS-700 5-Cup Coffee Maker
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Posted on Nov 03, 2013
When i turn on my delonghi magnifica pronto on its says insert brewing unit but its already in plus it makes a really loud noise when i turn it on
Sounds like the brewing unit, or infuser, has not been properly seated into its holder. Are you sure that the two red retainer fittings are in their snapped out positions? See page 16 of your owner's manual.
If the infuser has not been properly seated it could cause a loud noise when the servo drive tries to raise the unit into its brewing position.
Sep 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
Breville870xL loud noise when press brew buttons
The noise is caused by a (so-called 'magnetic' or sometimes 'three-way') solenoid valve's piston/plunger not seating properly or jamming when the solenoid is energized. This can be caused by too much gap between the plunger and the cylinder it's in, by roughness in the finish of the parts, or wear and tear - and indicates a faulty solenoid valve.
A bad solenoid isn't something that's repairable. It needs to replaced. There are two solenoid valve assemblies in that model, make you you get the correct one.
Feb 02, 2014 | Breville BES830XL
When it is brewing it make a loud noise during the brewing
Any coffee brewer will bring water to a boil and expel the hot water over grounds or into a container. This water is sometimes under great steam pressure and is released by the user with a knob, handle, etc. These pressurised machines all make noises but should be within the normal operating range while using the machine. If it makes noise other than when in use then there may be an issue. Have a technician check for safety reasons as you are dealing with a 'steam BOILER' . For drip makers there should be no pressure other than the normal 'glug-glug' sounds while brewing. A commercial brewer will just have water sprinkling down into the basket and possible 'whine' noise as the tank refills. But if it's not your normal noise then have a tech check it out. ukeboy2@yahoo.com
Oct 14, 2013 | Coffee Makers & Espresso Machines
Keurig loud squeaking noise
End of life procedure "Say Good Bye" or have a fire!
Mar 03, 2013 | Keurig B60 Coffee Maker
I can not release the main component in my Saesco de luxe. Here a loud clicking noise when machine is turned on.
Hi
The loud clicking noise is a broken brew drive. This usually happens when you use the pre-ground button but put more than the level scoop into the brew unit. The brew unit can't compress the coffee and jams the brew unit which breaks the drive gears. Drive gears have to be replaced. I have some drive units complete.
Oct 26, 2011 | Saeco Magic De Luxe Espresso Machine
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
My Keurig single brew has started making noise.
TAKE IT BACK! ! If it is only a month old and you still have the box and or reciept, it should be covered under warranty
Dec 28, 2009 | Keurig B60 Coffee Maker
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Aug 01, 2008 | Starbucks Saeco Italia Digital Barista...
Cuisinart SS-700 5-Cup Coffee Maker Logo
653 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
