Question about FAIP Vertical Shaft Pump MTPV93519
What oil and how much do you put in on pump #mtpv93519
Where Is The Oil Pump Located>? And How Do I Replace The Oil Pump
Here you go. BIG Job!
http://www.ehow.com/how_4506339_replace-oil-pump-ford-taurus.html
The oil pump is an essential piece of equipment that keeps your Ford Taurus running. It lubricates the engine by keeping the oil circulating. Without this lubrication, the engine wouldn't run. An oil pump is usually located in the oil pan. If you want to change the oil pump and replace it with a new one, roll up your sleeves and get ready for some dirty work.
How to Check if an Oil Pump Is Bad
Things You'll Need
  • Wrench
  • New oil pump
  • New A/C bolts
Remove Old Oil Pump
  1. Drive your Ford Taurus up onto ramps or lifts so you have room to work as you pull out the oil pump. You could also use a jack, but make sure you brace the front wheels so they don't roll. In addition, set the emergency break firmly into position so the car doesn't roll.
  2. Take the engine out and put it on an engine stand then remove the upper intake manifold. Take off the valve covers then the accessory drive belt.
  3. Remove the power steering pump and the alternator. The water pump is the next component to remove, followed by the A/C compressor and bracket.
  4. Rotate the pulley shaft clockwise to remove the crankshaft pulley. It has left-handed threads.
  5. Pull out the oil pan and the oil pump screen and tube. Take off the front cover and the timing chains and remove the crankshaft timing gears. Finally, remove the oil pump, taking note of the bolts you removed and in which order you remove them.
Insert New Oil Pump
  1. Install the new oil pump and put the bolts back on in the same manner you removed them. Tighten these bolts to 71 to 106 in-lb.
  2. Reinsert the crankshaft timing gears, timing chains and front cover. Put the oil pump screen and tube back on, torquing the bolts to 71 to 106 in-lb, and torque the nut to 15 to 22 ft-lb.
  3. Put the oil pan back in, then the crankshaft pulley. Install the A/C compressor and bracket using new bolts for the A/C. Add the water pump, alternator, power steering pump, the accessory drive belt, valve covers and upper intake manifold.
  4. Replace the engine back into your Ford Taurus and fill the crankcase. Start your engine and look for leaks in the area you were working.
Read more : http://www.ehow.com/how_4506339_replace-oil-pump-ford-taurus.html
Aug 06, 2015 | 2004 Ford Taurus
Ok I have a 1995 ford aspire im trying to figure out how to replace the oil pump
Disconnect the motor mounts and jack the engine to remove the oil pan. Remove the oil pan, replace the oil pump you'll find at the end of a pick up tube, replace the pump and put the pick up tube back on the new pump making sure it's in the same low position it was when removed, replace the oil pan gasket and put the oil pan back on, lower the engine and put the motor mount bolts back in. Put in the proper amount of oil and go.
Nov 13, 2014 | 1995 Ford Aspire
How to change the oil pump on 2007 chevy 4.8
Remove oil pan.
Mark and Remove distribuator.
Remove bolts to oil pump and remove.
Install new oil pump.
Reinstall oil pan with new gaskets.
Put in new engine oil.
With a large straight screwdriver. Rotate oil pump (clockwise for top) through the distribuator hole until a huge anount of resistance is felt.
Reinstall distribuator where marked. ( you may have to rotate tang on oil pump to get distribuator to go down. .
Start and run.
Jul 01, 2014 | Cars & Trucks
What oil does my troybuilt pressure wash use, its 4.5 hp unleaded gas 4500 psi? it just stalled while i was using it looked like oil was low, i have no manual and there was no info on unit so i added...
There is no way that a 4.5 hp engine can create 4500 psi. If you are putting the oil into the engine it would just take a 10w30 motor oil, if you are putting oil into the pump I would have to know what pump kind of pump you have, if the name isn't on the pump I would need to know the model number of the machine. The oil in the pump shouldn't have any affect with the motor not starting though.
Oct 24, 2010 | Briggs & Stratton Garden
Had the oil changed at walmart they put a fram filter on it and the filter caved now the motor appears to be locked up if the oil pump went out would it appear that the motor was locked up my husband...
Yes it is bearings, rings, and part of the cylinder. If the oil pump went out the motor would lock up. The oil pump pumps oil throughout the motor. If the pump quits, it is just like running the engine without any oil at all. Without oil pressure then the motor would lock up because nothing in the engine would get any lubrication. Don't think it has anything to do with the oil and filter. Probably just a faulty oil pump. I have heard of Walmart not putting oil back in cars, and causing them to lock up. But if you had oil in the car, and it has metal shavings, then it is more than likely the oil pump just quit.
Oct 02, 2010 | 2002 Subaru Outback
Someone put motor oil in power steering fluid
drain all the oil in your power steering system then fill it up again with atf.
May 27, 2010 | 2004 Saab 9-3
Mechanic mistakenly put gear oil in tank, the pump is knocking
What the heck did he think he was putting in the tank? Gear oil is very thick and heavy, so the fuel pump may have a problem as it is meant to pump gas, which is not thick and heavy like gear oil. There was probably some gear oil in the tank while the pump was operating, and it pumped some gear oil for a short time, which damaged it. Insist that the 'mechanic' replace the fuel pump at no cost to you ,and find a new mechanic for future repairs. Good luck.
Nov 09, 2009 | 1991 Mitsubishi Galant
Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
May 19, 2009 | Karcher 2500 PSI Pressure Washer
OIL PUMP PROBLEMS
check valve in or check oil filter,did you do the timing belt,that runs the oil pump on a 2.0
Mar 19, 2009 | 1996 Plymouth Breeze
OIL PUMP PROBLEMS
the oil pump is not electronic it is gear drivin . either the gear is bad or the installation was done incorrect. my advice is to start over and sure the rod is seated correctly . you should be able to put the rod in and not be able to spin it. if it spins that means either the gear is completely bad or the rod needs replacing or both. in order to replace the gear you have to remove the timing chain. in your vehicle if you have a distributor and not coil packs you have to remove the distributor and look at the bott of the shaft to see if it is worn out. hope this helps........please rate this.
Aug 31, 2008 | 1999 Ford Taurus
FAIP Vertical Shaft Pump MTPV93519 Logo
82 people viewed this question
Top FAIP Garden Experts
andy just round the...
Level 1 Expert
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Mister Danger
Are you a FAIP Garden Expert? Answer questions, earn points and help others
