Question about Garden
Ohv 400 gardeners choice stroke lawn mower wont start
    New Friend:
  • 38 Answers
Adjust the valves, if u have fire and fuel
Posted on Oct 14, 2013
2 Suggested Answers
  • 26 Answers
SOURCE: ohv 400 gardeners choice lawn
Are you trying to start the machine without sitting on it? There may be a kill switch under the operator's seat that won't let the engine start without the operator sitting on the seat.
Posted on Oct 07, 2010
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
Craftsman lawn tractor with 18 b&s ohv motor blows dipstick out while cranking. Valve lash is good.
check to see if the flywheel key has been sheared off. if so replace it
Sep 13, 2016 | Craftsman Garden
How many cc's is my Sanli Lazer cut OHV 400 4 stroke. Can't find it anywhere . ? Cheers
most of these motors are the same as the B&S engines and others
135cc's or around the 3hp power range
Mar 01, 2016 | Garden
Lawn mower wont start after oil change
i can only check for spark if you have spark then go to the carb. check for fuel flow if you have flow clean your carb. one of these is bad.
Apr 22, 2014 | Mtd 19 In. 173 CC OHV 3-In-1
I have a troybilt lawn mower has a 17.5 briggs in it has ohv my question is how to check to make sure its still in time
You can do a quick check, bring the piston up to top dead centre non compression stroke, at this point the exhaust and inlet valve should be rocking if not the valve timing is out.
Jul 01, 2012 | Troy Garden
Ohv 400 gardeners choice lawn mower doesn't want to start, got petrol, got oil and the air filter is clean. It's still very new, only used about three times, haven't used it for more than 6 months. Please...
Oct 07, 2010 | Garden
I have a OHV 400 Gardeners choice 4 stroke lawn mower that is less than 12 months old only used 5 x. Last Time being xmas eve!! I went to mow yesterday an it started ok But died within a minute of this?? I...
remove the sediment bowl located on the lower side of the carburator and dump out sediment then you can check the operation of the float because this is where its located
Jan 17, 2010 | Garden
13.5 OHV B&S won't stay running, blows gas out carb.
Sounds like you have a blown valve. I'm assuming this is a 4 stroke motor, if it was 2 stroke then it would be the reed valves. But either way it's the valves.... unfortunately that will require a mechanic :(
Jul 19, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
205 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
