Question about Samsung DVD-HR720 DVD Recorder
Troble tuning in
Hi im having trouble tuning in the tv channels into the dvd player. After scaning it comes up saying no channel is memoried. Check aerial or cable. There is nothing wrong with our cable or aerial as how tv and digital set top box is picking up channels. This problem has happen before and i just pulled it out of the wall and turned it back on and it worked. I have tryed pressing every button and read the book and i cannot seemed to get it to tune in. Please help. Thank You
  • Anonymous Mar 16, 2014
    Purchased new Akai AK24FLEDG yesterday. Cannot get any further than 'first time installation' panel and 'channel tuning' where zero channels are selected. After that, it's just 'No Signal'.
    Ordinary wall socket aerial used which worked perfectly well with previous (non digital) set. Other TVs in the house working OK from same aerial system.
    Any solutions please?
  • 61 Answers
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Posted on Jan 27, 2008
SOURCE:
Unable to tune my liteon dvd recorder DD-A300 to a panasonic tv
I'm a bit confused about what you are trying to do? DVD recorders don't tune in to TV's anymore. They output the signal to the TV via a connector such as HDMI. To record the recorder will need an aerial feed etc, which can be split using a splitter between what feeds the TV and Recorder.
Dec 20, 2012 | Televison & Video
Bought a Dynex RF modulator, model WS-007, for my dad so he can watch DVD's on the TV with a minimum of hassle (e.g. no switching to video input) . Problem is when DVD player is switched on and DVD is...
Make sure you have the TV tuned to the modulator's output channel (3 or 4 as set by the switch on its rear panel). Also, turn the modulator on first, and then tune the TV to the modulator channel. This will make sure the set properly adjusts its automatic fine tuning. What you're describing sounds like the TV isn't exactly on the channel.
If the trouble continues, try switching the modulator to its other channel and see if the sound clears up. Enough of an interfering signal may be getting through where you have it set now.
If you still have no success, return the modulator and exchange it. These aren't high-precision devices, and often the output frequency is slightly off. On most TVs it's not a problem, but some tuners are more finicky than others.
Mar 01, 2011 | Dynex RF Modulator AV Signal Converter
I tuned the tv on and after it scane the channels the tv came i have atleast 60 channels now i only have 29... channel 30 says audio only 30 thru 60 no picture, and then the channels say like 30.20
Is your televison set to cable mode or broadcast mode?
Who is your cable provider?
Comcast recently, in my market disabled the ability to receive the new digital format unless you use their converter box.
Jan 04, 2011 | Televison & Video
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
I am having troble conecting my vcr to tv, dvd plarer and Virgin cable box. Auto set up didn't work and I cannot tune in manually. To make matters worse the vcr thinks my video channel is channel 4 whereas...
try this unhook it all start over first hook the cable box up to the vcr witch would be the wire that says out of the cable box gose in to the ant on vcr the tv cable from the vcr gose to the back of the tv the dvd player gose into the rca jacks on the rear vidio audio in just match up the colors make sure all cables that screw in are snug up as it will degrade the signal if to loose then go to set up in the vcr and if it has a auto option for set up use it . hope this was helpfull
May 28, 2010 | Sony SLV-740HF VHS VCR
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Samsung DVD-HR720 DVD Recorder Logo
186 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
