Question about Air Tools & Compressors
How to change pressure setting on SG Intellisys Controller 39875158 Unable to change offline pressure 103psi and online pressure 93psi on Controller.Please advice the procedure to do so.If there is a hidden button then tell me where.
  • Phill Lostboy
    Phill Lostboy Oct 14, 2013
    Accessing the Factory Set Point Menu for the
    Ingersoll-Rand Intellisys Controller
    In order to access the factory set point menu for the
    Ingersoll-Rand Intellisys controller,
    1. Stop
      compressor. 'Ready To Start' must be displayed in the lower left corner of
      the display.
    2. Press
      the Menu button twice.
    3. Press
      the Load button once.
    4. Press
      the Unload button once.
    (The button
    sequence must be completed
    within
    three seconds.)
    Factory Set Points will now be displayed.
    When installing a new controller, configure the factory
    set points menu and then return to the main menu and configure the operator set
    points and integral sequencing.
    This information should be copied from the old controller
    and used to program the new controller.
    Novelist:
  • 214 Answers
For and SG controller use the following instructions to access factory setpoints which will allow you to change the pressure setting. Note : look at the metal data tag affixed to the compressor for the correct pressure setting. (eg: 125 psi) do not exceed the data tag pressure or premature damage to the compressor and personal injury may occur.
To access... Power must be applied to the
compressor with READY TO START showing in
the display.... press the center (MAIN MENU)
display button two times and then press the LOAD
button followed by the UNLOAD button, all within
three seconds.
To change settings... The values of the Factory
Setpoints can be changed using the same buttons
and procedures used to change the Operator
Setpoints. Refer to the Operator's Manual for
details.
To exit... Press either the STATUS or MAIN MENU
buttons. If no buttons are pressed within 30
seconds, the display will automatically return to
the Current Status screen showing Package
Discharge Temperature and Airend Discharge
Temperature
Posted on Oct 17, 2013
2 Suggested Answers
  • 214 Answers
SOURCE: I need to set up a intellisys controller
David ,I will need more info like type of intellisys controller. IR actually has at least 4 intellisys controller. Need to know what controller you have. Model and serial #, HP, voltage, Ep,XF,HP, Y-delta start or DOL start. pressure rating from ID tag. Some info can be obtained from the metal tag affixed to one end or in the electrical compartment (ID tag)
Posted on Nov 04, 2011
Ingersoll Rand Part# 39875158, SG Intellisys Controller showing overdurrent when motor is ok
check if the voltage supply is ok or the tranformer on the panel is not giving over voltage
Sep 30, 2014 | Air Tools & Compressors
For the SG intellisys controller, how do you change the online pressure setting?
Goto Main Menu, Operator Setpoint select, Offline/Online. Up/down key to change value.
Jul 08, 2012 | Ingersoll Rand Stationary Air Cooled...
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
Nov 02, 2011 | Ingersoll Air Tools & Compressors
Air Tools & Compressors Logo
1,109 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
