Question about MagnaFlow 2005 Dodge Magnum - 2.7L V6, with federal emissions system - Catalytic Converters - 49 State Legal
Ignition coil wiring diagram
Replaced coil boot and plug on cylinder 1 computer still says coil not firing on cylinder 1
2 Suggested Answers
  • 44448 Answers
SOURCE: Have question on firing order identification .
try the alphabet as numbers as numbers so that 1234 would be equal to abcd and 5678 would be efgh if that is correct the e coil would be on no 5 piston plug
that is if you have 8 individual coils for the pistons
Posted on Sep 18, 2015
Cylinder 1 and 4 not firing
have you checked for codes. you should have power and ground at the coil plug. note the computer is what grounds the circuit to fire the ignition coil. if you don`t have a ground then it could be a bad coil driver in the computer, which means you will have to have the computer replaced a possibly programed to the car.
Aug 16, 2014 | Cars & Trucks
P0302 cylinder 2 misfire detected
the problem is a sparkplug or wire you must be replaced
Apr 22, 2014 | 1999 Toyota 4Runner
Coil pack plugs diagram ignition
Make sure computer was cleared from old error. Check or replace #2 fuel injector. Spark plug wires can be replaced individually, you might want to replace #2 wire.
Dec 30, 2013 | 2002 Lincoln LS
98 harley sportster 883 not firing...will not start....replaced literally everything. What am I missing?
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections especially the negative cable at "BOTH" ends
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below. Good luck and have nice day.Harley Davidson Wiring Diagrams and Schematics Harley Davidson Manuals Mark Workshop
Harley Davidson Sportster error codes and how to access them
Jun 17, 2012 | Harley Davidson Motorcycles
1999 ford escort I changed the plugs, but broke a plug cap. Bought a generic replacement spark plug wire that had to be modified to fit into the head. I cannot get the firing order correct. The car...
Remove the plugs from the head. Insert into the coil wires. Make sure they are properly earthed on the engine. Crank the motor and check for spark at each of the plugs.
Refer to the diagram. Cylinders are connected as shown on the diagram in blue. 1 goes to cylinder 1(sparkplug furthest from coil pack), 2 to 2, 3 to 3 and 4 to 4(closets to coil pack).
To test the coil pack use a digital volt meter. Measure resistance between coil towers for coil 1(marked 1 in red on diagram) Value should be between 12000 and 14500 ohm. Do the same for coil towers 2.
Measure resistance between I and C1. If the measurement is more than 5 ohm the coil is defective. Do the same for I to C2.
Measuring voltage at I(Ignition start/run) to ground should be 10V.
I is connected to the 15A engine fuse. The radio interference capacitor is connected between this line and earth at the coil. Disconnect it to see if it cures the problem.
C1 and C2 connect to the powertrain control module.
Bear in mind that aftermarket coil wires may cause problems with misfiring, so see if you cant find an OEM coil wire to replace the broken one before replacing anything else.
Nov 15, 2010 | 1989 Ford Escort
Miss fire 1 and 5 changed wires and plugs
Probably coil pack. Follow spark plug wire from spark plug to where it plugs in, that is your coil pack.Some are seperatable. Depending on motor size you may have coil over plug. You said wires not (cop) coil over plug boots.If it is coil over plug it is just a boot you changed in that case the coils plug into boots & on plug & an electrical connector. They are seperate for each cylinder.
Jun 06, 2010 | 2003 Ford E250
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
Replace spark plugs on a 2008 4 cylinder tribute
This is a fairly easy job. Do each cylinder one by one (removal and install), make sure to reinstall the coil on the same exact cylinder (DO NOT MIX UP). 1. Remove coil retaining scre 2. Pull upward on the coil to remove. 3. Remove spark plug (using a spark plug socket). 4. Properly gap new spark plug (if applicable). 5. Apply sprark plug anti-seize compound on plug threads. 6. Install plug. 7. Aplly coil boot grease on the coils' rubber boot tips. 8. Reinstall coil.
May 22, 2010 | 2008 Mazda Tribute
P0304* Cylinder #4 Misfire on a 1999 dodge intrepid. were is this cylinder located.
This would be the forth cylinder from the front(where the pulleys,and belts are).There will be a coil,and under the coil,is a boot,connected to the spark plug.The miss fire could be any,of the three.I would replace the spark plugs (all four)and the boots.Then if the miss fire is still there,replace the coil,on number four cylinder.
Dec 08, 2009 | 1999 Dodge Intrepid
MagnaFlow 2005 Dodge Magnum - 2.7L V6, with federal emissions system - Catalytic Converters - 49 State Legal Logo
Top MagnaFlow Electronics - Others Experts
Lawrence Oravetz
Vernon Taylor
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
